sveness Report post Posted 03/17/2005 10:25 AM Hi there My problem is intermittent and seems to have something to do with the get numbers module verification process. I am verifying a number by checking it against an oracle database. If no record is returned VoiceGuide plays "Notvaliddelno.wav" else "thankyou.wav" is played. When the module returns the "verify_failed" result, it plays "notvaliddelno.wav", but occasionally does not play the file and hangs on "112712.68 6 LsGetNbrsPlayWelcMsg EV_TIMEOUT_CHECKONSTATE" Here is the code in get numbers module: set vg = CreateObject("VoiceGuide.CommandLink") sResult = "verify_failed" set cnOracle = CreateObject("ADODB.Connection") set rsOracle = CreateObject("ADODB.Recordset") cnOracle.Open "Provider=msdasql;DSN=nctprod;UID=nct;PWD=clone;SERVER=nctprod;" set rsOracle.ActiveConnection = cnOracle oracleSQL = "SELECT M.DELIVERY_NOTE_NUMBER, D.REFERENCE, M.TO_DPOINT_CODE FROM MOVEMENTS M, DESPATCH_POINTS D WHERE M.DELIVERY_NOTE_NUMBER = $RV_ENTEREDNUMBER AND M.FROM_DPOINT_CODE = D.DPOINT_CODE AND RELEASE_DATE IS NULL" rsOracle.Open oracleSQL, cnOracle, 3 if not rsOracle.EOF then sResult = "verify_passed" End if rsOracle.Close cnOracle.Close set cnOracle = Nothing set rsOracle = Nothing vg.Run_ResultReturn $RV_LINEID, sResult set vg = Nothing Attached is the event trace log. Thanks 0317vgm.txt Share this post Link to post
SupportTeam Report post Posted 03/17/2005 12:09 PM Trace shows the verification script was ran OK and returned "verify_failed". Do you have the path "verify_failed" or "Failed" defined in that module ([GetDelNo]) ? Can you post the script? 112711.66 6 eng copy of verification script ran: vbs_6_1.vbs 112711.75 6 Run Script waiting. iRunWait=1 (shellid=1344, process=1780) 112711.77 6 timer set 1 EV_TIMEOUT_CHECKONSTATE 112711.99 6 cl Run_ResultReturn >>verify_failed<< 112711.99 6 ScriptEventCode 9220 iLineState=1301 112712.00 6 LsGetNbrsRxDigits EV_UNKNOWN_9220 112712.00 6 eng GetNbr EV_MODGETNBRS_VERIFY_FAIL 112712.66 6 timer fired EV_TIMEOUT_CHECKONSTATE 112712.66 6 ScriptEventCode 9007 iLineState=1300 112712.68 6 LsGetNbrsPlayWelcMsg EV_TIMEOUT_CHECKONSTATE Share this post Link to post
sveness Report post Posted 03/17/2005 12:12 PM submitted the script with original post, definately "verify_failed" Share this post Link to post
SupportTeam Report post Posted 03/17/2005 10:07 PM The file attached to the first post in this thread is a trace log, not the script - the script is the .vgs file. Share this post Link to post
SupportTeam Report post Posted 03/18/2005 08:45 AM Please update your v.5.2.3b install with attached .exe VgMulti_5.2.3074.zip Share this post Link to post
sveness Report post Posted 03/18/2005 12:47 PM Thanks for that quick response, brilliant support! Please could you explain (in laymans terms!) what was wrong. Thanks Shane Veness NCT Forestry Co-operative Limited Share this post Link to post
SupportTeam Report post Posted 03/18/2005 09:39 PM There was a bug in the way the verify_failed was handled by that module... The 'verify number' functionality was originally designed for the "VoiceGuide for ISDN" and "VoiceGuide for VoIP" product line and was only recently put into the version of VG which you can download from our WWW. Look like it wasn't ported over from that other version properly. This was now fixed. Share this post Link to post
