Vgemailsender Fails Sending
I'm aquired a problem all of the sudden wurs on this nowhere the Vgemailsender.exe disconnect half way through sending. I've spent hours and now. Tried different mail servers etc.. I have no problem using Outlook or Thunderbird etc.. to send or receive. Anyway below is a trace 10 log. You'll notice it starts to send, then gives the "NOTE smtp explicit .Connect removed" and never sends the complete mail. Keep in mind too this all worked fine for months. Last thing I did was put Spybot Search and Destroy and the Lavasoft Ad-Aware to cleanup before an image. Anyway I'm really out of ideas. You guys gave me a new Vgemailsender.exe for MailEnable at one point so I've been trying different builds of it. Virus scanned. Reinstalled Service pack 2 on 2003. Checking port usage and I only see my mail server on port 25/110. Server has worked fine for 2 years. I'm really at a loss here why. Help please!! Thanks.. :)
115546.30 0 eng prog start 11:55:46 20 Nov
115546.41 0 que varDialEntry(31,0)=0
115546.41 0 que .bHtml = False
115546.41 0 que found 1 ready to send emails in the database.
115546.41 0 que current: ID=1
115546.42 0 que update ID=1 to: SendTime=0811201156 SendRetriesLeft=0
115546.42 0 smtp EmailSmtpQueueSend [dbov21@yahoo.com],[dbov21@yahoo.com],[Notify@PhoneaHome.com],[PhoneaHome Description Service],[Admin@PhoneaHome.com],[],[],[],[Notify@PhoneaHome.com],(subj),(msg),[.
qcp],0,localhost,1,0,Notify@phoneahome.com,otsadmin,,25,False
115546.42 0 smtp .MaxRecipients orig=100 new=10000
115546.42 0 smtp could not find file [.qcp] => [0,,,0]
115546.42 0 NOTE smtp explicit .Connect removed
115546.42 0 smtp send start
115546.42 0 ---------------------------------------------------
115546.42 0 To:dbov21@yahoo.com, Cc:Admin@PhoneaHome.com, Bcc:, AsHTML=False
115546.42 0 PhoneaHome ID# 4
115546.42 0 *****Attention Agent*****
Voicemail Attached: No
Agent: Top Producer
Agency: PhoneAHome
Phone: 8053410513
Email: dbov21@yahoo.com
UserName: demo
A call was just made to the PhoneaHome Listing Service regarding the attached listing from the following party.
Call Info
CallerID Name: UNAVAILABLE
CallerID Number: 8053895200
Language: English
Time: 11/20/2008 11:55:22 AM
Length: 23 seconds
IPhone Edit Link:
http://phoneahome.com/admin/index.php?acti...ings&edit=4
115546.42 0 smtp Status Connecting to SMTP Server (localhost)...
115546.50 0 smtp Status Initializing Communications...
115546.50 0 smtp Progress 2%
115546.52 0 smtp Status Sending Login Authentication...
115546.52 0 smtp Progress 3%
115546.53 0 smtp Progress 6%
115546.55 0 smtp Progress 8%
115546.63 0 smtp Status Host Login OK!
115546.63 0 smtp Status Sending Sender Information...
115546.63 0 smtp Progress 4%
115546.64 0 smtp Status Sending Recipient Information...
115546.64 0 smtp Progress 6%
115546.70 0 smtp Progress 10%
115546.72 0 smtp Status Sending Message...
115550.36 0 eng prog start 11:55:50 20 Nov
115550.47 0 eng prog end 11:55:50 20 Nov
115600.39 0 eng prog start 11:56:00 20 Nov
115600.50 0 que varDialEntry(31,0)=0
115600.50 0 que .bHtml = False
115600.50 0 que found 1 ready to send emails in the database.
115600.50 0 que current: ID=1
115600.50 0 que update ID=1 to: SendTime=0811201157 SendRetriesLeft=-1
115600.50 0 smtp EmailSmtpQueueSend [dbov21@yahoo.com],[dbov21@yahoo.com],[Notify@PhoneaHome.com],[PhoneaHome Description Service],[Admin@PhoneaHome.com],[],[],[],[Notify@PhoneaHome.com],(subj),(msg),[.
115600.50 0 smtp .MaxRecipients orig=100 new=10000
115600.50 0 smtp could not find file [.qcp] => [0,,,0]
115600.50 0 NOTE smtp explicit .Connect removed
115600.50 0 smtp send start
115600.50 0 ---------------------------------------------------
115600.50 0 To:dbov21@yahoo.com, Cc:Admin@PhoneaHome.com, Bcc:, AsHTML=False
115600.50 0 PhoneaHome ID# 4
115600.50 0 *****Attention Agent*****
Agent: Top Producer
Agency: PhoneAHome
Phone: 8053410513
UserName: demo
Call Info
Language: English
Length: 23 seconds
IPhone Edit Link:
115600.52 0 smtp Status Connecting to SMTP Server (localhost)...
115600.55 0 smtp Status Initializing Communications...
115600.55 0 smtp Progress 2%
115600.56 0 smtp Status Sending Login Authentication...
115600.56 0 smtp Progress 3%
115600.58 0 smtp Progress 6%
115600.59 0 smtp Progress 8%
115600.61 0 smtp Status Host Login OK!
115600.61 0 smtp Status Sending Sender Information...
115600.61 0 smtp Progress 4%
115600.64 0 smtp Status Sending Recipient Information...
115600.64 0 smtp Progress 6%
115600.66 0 smtp Progress 10%
115600.67 0 smtp Status Sending Message...
115604.48 0 eng prog start 11:56:04 20 Nov
115604.59 0 eng prog end 11:56:04 20 Nov
115606.52 0 eng prog start 11:56:06 20 Nov
115606.63 0 eng prog end 11:56:06 20 Nov
It's hard to say why the email is not getting sent. First thing to try would be to remove the recently installed software on the machine and see if that takes the system back to the working state as before.
I actually fixed this. I was using "localhost" for my mailserver name which has worked forever. Works fine for outlook and Thunderbird still, but not for the vgemailsender.exe. Use the real email server name.
