Where To Find Release Notes For New Versions
#1 darylr 18 August 2017 - 09:15 AM
I am currently running 7.5.7 and the latest version is 7.5.12.  Where can I find the release notes that describe the changes.  I'm trying to decide if I need to keep up to date or can stay with what is working.
We've been online for about 9 months now and the system is working great!
thanks!
Daryl
#2 SupportTeam 19 August 2017 - 10:34 AM
Main changes are:
The way that the 'Run Program' and 'Run VBScript' modules start their tasks.
Specifically: if task cannot be started using the 'Local System' login (because for example it requires UI access) then the account of the currently logged in user is used.
The Web Service module was modified to be better handle more complex responses.
Some of the Result Variables created by the "Call Web Service" module have changed as part of this modification.
Other changes are private custom extensions made for specific users. These are not publicly documented.
If your system does not require additional features then would recommend continuing to use your current setup as-is.
