Inactive Globalrv
vgEngine trace shows that the GlobalRV entry in [scripts] section of VG.INI file was not set to anything when the VoiceGuide service was started.
Perhaps the VG.INI was not saved, or was saved to wrong location on hard disk?
161247.963   6               [Scripts]:GlobalRV =
I run VG in test mode to be sure all works properly. no other vg.ini
In vg.ini we changed
Scripts=OFF
and
[scripts]
GlobalRV=[server_id]{46}[CDR_amaflags]{46}
but vg shows
101213.357   6               [Log]:CDR_LastData_SaveRv not set. default is 0
101213.357   6               [Log]:CallEvents not set. default is 1
101213.357   6               [Log]:Scripts=|ON|
101213.357   6               [Scripts]:GlobalRV =
strange
after reinstal VG to version
102755.381   6               ------------------------------------------------------------------------------------------------------
102755.381   6               vgEngine : 7.5.6391.1059 RELEASE options75
102755.381   6               Compiled : 2017-06-30 23:35:18.28
102755.381   6               Location : C:\Program Files (x86)\VoiceGuide\vgEngine.dll
102755.381   6               Written  : 2017-06-30 15:38:10
102755.382   6               trace lvl=10, encoding=System.Text.ASCIIEncoding (ASCII)
VG read vg.ini properly.
102757.016   6               [Log]:CDR_ODBC_ConnectString =
102757.016   6               [Log]:CDR_LastData_SaveRv = 0
102757.017   6               [Log]:CallEvents not set. default is 1
102757.017   6               [Log]:Scripts = OFF
102757.017   6               [Scripts]:GlobalRV =[server_id]{46}
