I Can't Do Outbound Calls
Hello,
I have a problem with outbound call v 7.0.3695.17666, I registered one line in asterisk, when I called VoiceGuide IVR it answered good then I put on Outbound Call loader a external number and I configured script part but when I click "Load Phone Numbers" buttom it never sent the call, my configuration is the following:
number: 956203099 (in phone numbers menu)
campaing name: test (in phone numbers menu)
scheduler: 0 - Autodialer (in phone numbers menu)
script to run when a live person anser is detected: credit card payment (in scripts menu)
Do I need to set up anymore?
Regards.
Could you please post a copy of VoiceGuide's Debug Traces which captures the system startup and the attempted outgoig call, this will allow us to see what happened.
Trace Log files are created in VG's \log\ subdirectory.
Hello,
I did another test and I worked good, I only put after the call number the IP of my SIP server for example:
956405699@10.10.10.9
With that all worked good.
Thank you and regards.
