Strange Disconnect Tone. Pbx Expert Can Not Learn.
I would welcome some help on the following problem.
I am having a problem getting VG to recorgnise the diconnect tone. I have tried to use PBX expert but it failed at the step when trying to learn the disconnect tone.
I am using an old PBX called BT revelation in the UK.
I have also tried to follow your tutorial on using Audacity but I could not work out the frequencies and cadence.
I have attached the disconnect tone maybe you could help me find out the settings.
Many thanks
disconnect.wav
This is just a single tone of about 430Hz which is on for about 5 seconds.
Try these settings:
<Freq1>430</Freq1>
<Freq1Dev>50</Freq1Dev>
<Freq2>0</Freq2>
<Freq2Dev>0</Freq2Dev>
<On>100</On>
<OnDev>20</OnDev>
<Off>0</Off>
<OffDev>0</OffDev>
<Count>0</Count>
This did the trick. Support reamins as excelent as usual. Thanks very much for your help.
Try these settings:
<Freq1>430</Freq1>
<Freq2>0</Freq2>
<On>100</On>
<OnDev>20</OnDev>
<Off>0</Off>
<OffDev>0</OffDev>
<Count>0</Count>
