Having A Couple Problems
I'm trying to set up a system where the user can input different 4-digit numbers, and my system will play the corresponding audio file to that number. But I can't get the transfer to work - VG seems to only recognize single digit inputs.
Also, when I try to transfer to Voicemail Autoattendant or Voicemail Retrieve, the system hangs up on me.
Please help.
Also, if I want to dial out to transfer a call, do I need a separate phone line connected to my Dialogic card to dial out?
Use a Get Numbers module. See the "Credit Card Payment" demo script.
For 'Dial-and-Conference' transfers yes, but not if doing a 'Hookflash' type transfer.
Thanks. And what about my previous question: Also, when I try to transfer to Voicemail Autoattendant or Voicemail Retrieve, the system hangs up on me.
[Log]
VoiceGuide=10
[Log]
VoiceGuide=10
Done. Please look.
0219_ktTel.zip
Thanks for the traces. We have been able to find the path selection bug that you have encountered and have now fixed it.
Please update to the latest VG v7 available from our WWW Downloads page now.
Please let us know if you encounter any more issues with this.
