Old Dialogic Boards
I have several D140B boards and one D/121A board.
Can these be used with your software?
I plan on using the D/121A for here, but selling the others if they can be used.
TIA for any comments or feedback :-)
clesson@duke.net
Neither of these cards are supported...
The cards that are supported are listed on:
http://www.katalinatech.com/suppRecomHardware.htm
Above list is based on the Dialogic's "taprefnt.chm" help file, the relevat page I quote below:
Supported Hardware
The Dialogic Generation 2 TSP supports the following Dialogic boards:
D/4PCI
D/21D and D/41D
D/21H and D/41H
DIALOG/4
ProLine/2V
D/41E and D/41ESC
D/41EPCI
D/41JCT
D/42-NE2 (ISA and PCI)
D/120JCT-LS
D/160SC, D/160SC-LS, and D/160SC-HS
D/240SC, D/240SC-T1, D/240PCI-T1, and D/240JCT-T1
D/300SC-E1, D/300JCT-E1-75, D/300PCI-E1, and D/300JCT-E1-120
D/320SC
VFX/40ESCplus
Thanks...
I know what is listed as "Supported", but my question was NOT whether you support old boards, but whether it would work with them.
Do you know if anyone has tried?
I can't recall any user feedback regarding these cards - If you want to try using them and post your results here I think we'd all appreciate it,
I'll give it a try and let you know if it works.
This may be a while as the first priority is to find a system htat works with on or the other board(s). Lacking that I'll be 'trying' packages to see what works. Yours would be the 1st.
