Config Timeout
Hi VG Team,
I would like to set timeout of moduleGetNbrs is 10. So i have modified the setting using vg.ini:
Section:
[moduleGetNbrs]
entries:
Timeout_1stDigit=10
Timeout_Interdigit=10
Timeout_Confirm
=10
But when i run vg script to test, and check log file it's still not set, although i have restarted voiceguide system.
[moduleGetNbrs]:Timeout_1stDigit not set. default is 6
[moduleGetNbrs]:Timeout_Interdigit not set. default is 6
[moduleGetNbrs]:Timeout_Confirm not set. default is 6
Thank you for your support
Could you please post the VG.INI file and the vgEngine trace that captures the latest VoiceGuide service restart.
