Play Module How To Set Fax Receiver.
I am newer to voiceguide.
I want to send fax to someone in voiceguide script。
I Know "A Play module can be used to send a fax. Just specify a PDF or TIFF or JPEG file as the file to be "played" by a Play module".but I don't know how to set fax receiver.
if I use play module to play tiff file, so who will receive this fax?
sorry for my poor English 。please give me some advice ,thanks very much!
If you want to receive the fax on the same call then the caller must be making the call from a fax-capable device.
Like any of these: https://www.google.com.au/search?tbm=isch&q=fax+telephone
then when the Play module starts sending the fax the caller just presses the "Fax" button on their machine to receive the fax.
If you want to have VoiceGuide make a new outgoing call and send a fax on this new call then you can load the call using the Send Phone Message module:
http://www.voiceguide.com/vghelp/source/html/moddeliverphonemessage.htm
and specify the TIFF file as the message to be sent. An outgoing fax call will then be made.
