Script Changes For Vg7
I have VG 6 system installed and it works.
Now I test VG7 and my old script doesn't work in a way it works on VG6. Are VG7 scripts incompatible?
At least, I've found one difference:
I did as in your guide http://www.voiceguide.com/vghelp/source/html/modevalexpr.htm see Example 2
and in VG7 can't get in right way (expression is $RV[vDayType])
164731.828 8 3 state [checkDayMainMenu] Evaluate [$RV[vDayType]]
164731.828 8 3 rv replace start: [$RV[vDayType]]
164731.828 8 3 rvns: [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptPath]{d:\IVR\}[scriptsPath]{d:\IVR\}[$RV_STARTTIME]{2008-02-28 16:47:30}[$RV_DEVICEID]{3}[DlgcVoice]{dxxxB1C3}[DlgcNetwork]{dxxxB1C3}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{d:\IVR\}[vDayType]{WORKTIME}[vActivationEnabled]{FALSE}[vDateID]{}[vLang]{RUS}[vCa
lID]{200802281647303}[scriptWorktimeCheck_ResultReturn]{success}[playIntro]{1}
164731.828 8 3 rv replace end: [WORKTIME]
164731.828 8 3 eval[WORKTIME]
164731.843 8 3 CreateInstance ScriptControl objSC is: [system.__ComObject]
164731.843 8 3 objReturn is NULL
164731.843 8 3 rv add [checkDayMainMenu_Input]{WORKTIME}
164731.843 8 3 Eval Expr result:[]
164731.843 8 3 path {} not found
164731.843 8 3 matching path not found [], try boolean paths.
If I change expression to "$RV[vDayType]" I get what I need:
175340.015 8 3 rv replace start: ["$RV[vDayType]"]
175340.015 8 3 rvns: [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptPath]{d:\IVR\}[scriptsPath]{d:\IVR\}[$RV_STARTTIME]{2008-02-28 17:53:37}[$RV_DEVICEID]{3}[DlgcVoice]{dxxxB1C3}[DlgcNetwork]{dxxxB1C3}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{d:\IVR\}[$RV_CIDNUMBER]{}[vDayType]{WORKTIME}[vActivationEnabled]{FALSE}[vDateID]{}[v
ang]{RUS}[vCallID]{200802281753383}[scriptWorktimeCheck_ResultReturn]{success}[p
ayIntro]{1}
175340.015 8 3 rv replace end: ["WORKTIME"]
175340.015 8 3 eval[Cstr("WORKTIME")]
175340.015 8 3 CreateInstance ScriptControl objSC is: [system.__ComObject]
175340.015 8 3 rv add [checkDayMainMenu_Input]{"WORKTIME"}
175340.015 8 3 rv add [checkDayMainMenu]{WORKTIME}
175340.015 8 3 Eval Expr result:[WORKTIME]
175340.015 8 3 path {WORKTIME} found (at offset 3)
You should include quotes around the $RV if the $RV is a string.
Looks like in v6 the quotes were added in automatically for you if the default evaluation returned an error, I'm not sure why this isn't done automatically in v7 - we'll see if we can add this into v7 as well.
