Hangup The Call - Hipath 4000
It looks like the Dialogic card is reporting that the PBX is starting to turn the loop current on the line on/off every half a second and seems to continue doing this for a long time. This is an ususual thing to happen at end of call. Was something recently changed on the PBX to make it act like this?
I understand that you have been using the system for a while now, so I guess that this must be somthing that has only just now happened. We'd recommend you have a look at the way these extensions are configured on the PBX and change their configutation to the way that they were.
One thing you can try is to use this entry in ConfigLine.xml file:
<rule>
<Description>Do we send Disconnect on Loop Current Drop</Description>
<Key>SendDisconnectOnLoopCurrentDrop</Key>
<Value>1</Value>
<Default>1</Default>
</rule>
Set the value to 1 and then restart VoiceGuide and see if this case will be better handles by the software.
If the above does not work and you are unable to change the PBX line settings to the way they were before then we can probably make some changes in the software to accompadate this but we would only be able top mkae the changes in v7 of VoiceGuide, not v6 that you are using rigth now, so you would need to upgrade to v7.
141303.156 004 gc_GetMetaEvent returned. iDev=0, lEvtType=4, pEvtData=0x86, lEvtDataLen=92363192
141303.156 004 ev TDX_CST (CST Event Received)
141303.156 004 ev TDX_CST DE_LCON data=46
141303.156 004 ocxev DoFireDialogic(dwIdx=27, 4, 134, [TDX_CST], 46, 0, 0, [DE_LCON], [], []) (dwIdx=27)
141303.156 004 ocxev DoFireDialogic completed
141303.984 004 gc_GetMetaEvent returned. iDev=0, lEvtType=4, pEvtData=0x86, lEvtDataLen=92363192
141303.984 004 ev TDX_CST (CST Event Received)
141303.984 004 ev TDX_CST DE_LCOF data=83
141303.984 004 ev DE_LCOF does not cause DISCONNECTED event as Rule: SendDisconnectOnLoopCurrentDrop=0
141303.984 004 ocxev DoFireDialogic(dwIdx=28, 4, 134, [TDX_CST], 83, 0, 0, [DE_LCOF], [], []) (dwIdx=28)
141303.984 004 ocxev DoFireDialogic completed
141304.468 004 gc_GetMetaEvent returned. iDev=0, lEvtType=4, pEvtData=0x86, lEvtDataLen=92363192
141304.468 004 ev TDX_CST (CST Event Received)
141304.468 004 ev TDX_CST DE_LCON data=48
141304.468 004 ocxev DoFireDialogic(dwIdx=29, 4, 134, [TDX_CST], 48, 0, 0, [DE_LCON], [], []) (dwIdx=29)
141304.468 004 ocxev DoFireDialogic completed
141305.296 004 gc_GetMetaEvent returned. iDev=0, lEvtType=4, pEvtData=0x86, lEvtDataLen=92363192
141305.296 004 ev TDX_CST (CST Event Received)
141305.296 004 ev TDX_CST DE_LCOF data=84
141305.296 004 ev DE_LCOF does not cause DISCONNECTED event as Rule: SendDisconnectOnLoopCurrentDrop=0
141305.296 004 ocxev DoFireDialogic(dwIdx=30, 4, 134, [TDX_CST], 84, 0, 0, [DE_LCOF], [], []) (dwIdx=30)
141305.312 004 ocxev DoFireDialogic completed
141305.421 004 ocxfn PlayStop(hLine=4, lPlayId=0(0x0), lParam1=0, lParam2=0, strParam1=, strParam2=)
141305.421 004 dx_stopch call in PlayStop
141305.421 004 dx_stopch 4 ok
141305.765 004 gc_GetMetaEvent returned. iDev=0, lEvtType=4, pEvtData=0x86, lEvtDataLen=92363192
141305.765 004 ev TDX_CST (CST Event Received)
141305.765 004 ev TDX_CST DE_LCON data=46
141305.765 004 ocxev DoFireDialogic(dwIdx=31, 4, 134, [TDX_CST], 46, 0, 0, [DE_LCON], [], []) (dwIdx=31)
141305.765 004 ocxev DoFireDialogic completed
141306.593 004 gc_GetMetaEvent returned. iDev=0, lEvtType=4, pEvtData=0x86, lEvtDataLen=92363192
141306.593 004 ev TDX_CST (CST Event Received)
141306.593 004 ev TDX_CST DE_LCOF data=83
141306.593 004 ev DE_LCOF does not cause DISCONNECTED event as Rule: SendDisconnectOnLoopCurrentDrop=0
141306.593 004 ocxev DoFireDialogic(dwIdx=32, 4, 134, [TDX_CST], 83, 0, 0, [DE_LCOF], [], []) (dwIdx=32)
141306.593 004 ocxev DoFireDialogic completed
