Inband Signalling File Error.
Hello
Inband signalling file works correct in VG6 but in VG7 doesn`t.
From log:
144800.506 5 [PBX]:InbandSignalConfig = C:\Program Files\VoiceGuide\conf\InbandSignaling_SiemensHiPath4000.txt
144800.522 5 ERROR v7.1.3615.29799 (2009-11-24 16:33:18.41) mainLoad INI Config : Odwołanie do obiektu nie zostało ustawione na wystąpienie obiektu.
w .[1].()
w ..(String sAppPath)
Best Regards,
Grzesiek
Please update system to this version of VG v7: [old link removed]
and post traces from this version if you still encounter any issues with the Inband Signaling.
Now seems to be good. I will check this. Thank You.
Hello,
Inband signalling file is read by system but there is another error:
093053.180 6 3 2 Inband [*2011111524***] matched by pattern [[*][1-4]?????????[*][*][*]]
093053.180 6 3 2 Inband [inband_TOC] = [2]
093053.182 6 3 2 ERROR v7.1.3617.26571 (2009-11-26 14:45:42.40) Error_ScriptEventCode : Odwołanie do obiektu nie zostało ustawione na wystąpienie obiektu.
w vgEngine.ScriptRunsStateMachine.‘(Int32 iLineId, Int32 iCode, String sCode, Int32 lParam1, Int32 lParam2, Int32 lParam3, String sParam1, String sParam2, String sParam3)
w vgEngine.ScriptRunsStateMachine.(Int32 iLineId, Int32 crn, Int32 lCode, String sCode, Int32 lParam1, Int32 lParam2, Int32 lParam3, String sParam1, String sParam2, String sParam3)
093053.184 6 3 2 HangupCall, source=Error_ScriptEventCode, WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=0, lRecId=0
093053.184 6 3 2 ScriptWorkingMode set Stopping, (called from HangupCall)
Please give me some advice with it.
Best Regards,
Grzegorz
Could you please .ZIP up and post the InbandSignaling_SiemensHiPath3000.txt file.
It loos like one of the definitions in it (specifically the pattern [*][*]?*****????[*][1-4]) is incorrect and that is causing errors when trying to interpret the inband signaling data.
in InbandSignaling_SiemensHiPath3000.txt file.
change:
;3 digit station numbers, forwarded call - bluemedia zewnêtrznie 1
Pattern=[*][*][*]?*****????[*][1-4]
RV=Inband_TOC,4,1,Inband_Calling,7,3,Inband_Called,10,4,Inband_Info,17,1
;3 digit station numbers, forwarded call - bluemedia zewnêtrznie 2
Pattern=[*][*]?*****????[*][1-4]
RV=Inband_TOC,3,1,Inband_Calling,6,3,Inband_Called,9,4,Inband_Info,17,1
to:
RV=Inband_TOC,4,1,Inband_Calling,7,3,Inband_Called,10,4,Inband_Info,15,1
RV=Inband_TOC,3,1,Inband_Calling,6,3,Inband_Called,9,4,Inband_Info,14,1
Changes in Bold.
The values of '17' are more then the length of the pattern...
Future releases of v7 will flag instances of inband definition errors in the logs, but will continue on with the call.
