Blind Transfers
Jeff wrote:
We are running the working demo version of Voice Guide 4.9.0 on a PC running
Windows NT 4 with 40mb of RAM, equipped with a Dialogic D/42 card and a
ComDial Impact telephone system with an analog interface module. The
Dialogic and Voice Guide answer calls and play sound files without a
problem, but when a call transfer is attempted it is not executed correctly.
The transfer is never made, and the PBX system has to be reset for transfers
to be made anywhere else afterward. Here is the log generated by Voice
Guide:
39271 0 tapie linedevstate 2048 0 0
39401 0 tapie callstate OFFERING 12074816 0 4
39441 0 tapie callinfo CALLEDID
39461 0 tapie callinfo ORIGIN
39491 0 tapie ring 0
39521 0 Answer the call
39601 0 lineAnswer(12074816) => 7
40192 0 tapie callstate CONNECTED 12074816,1,0
40222 0 WorkingModeTAPI=
40262 0 WorkingModeScript=
40352 0 tapi Reply 7 0
40402 0 [Welcome] Playing
40462 0 [Welcome] Playing (C:\Program
Files\VoiceGuide\scripts\test\Menu1.wav)
41013 0 PlaySoundStart ok [C:\Program
Files\VoiceGuide\scripts\test\Menu1.wav]
41083 0 RunModule PLAY end
42836 0 tapie monitordigits 50 2
42896 0 LsPlayMsg [2]
43016 0 PlaySoundStop ok
43737 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
44027 0 [sales] Blind Transfer to 21 (Generate)
44388 0 tapic lineGenerateDigits(12074816,!) => 0
46751 0 tapie generate LINEGENERATETERM_DONE
47933 0 LsXferStart EV_TAPI_GENERATE
49215 0 LsXferPlayVts EV_HOOKFLASHFINISHED
49515 0 tapic lineGenerateDigits(12074816,21) => 0
49826 0 tapie generate LINEGENERATETERM_DONE
51018 0 LsXferPlayVts EV_TAPI_GENERATE
52299 0 LsXferPlayVts EV_TIMEOUT_HANGUP
52580 0 PlaySoundStop ok
52870 0 HangupCall called from []
53161 0 Hanging up call...
53441 0 PlaySoundStop ok
53731 0 fnHangupCall end
54022 0 tapie linedevstate 2048 0 0
54312 0 tapie callstate IDLE 12074816 0 0
54603 0 WorkingMode@Idle=
54943 0 set EV_TIMEOUT_TIMETOREINITLINE 2
55234 0 tapi Reply 8 0
56425 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
56706 0 ReinitTelephony due to IDLE start
57006 0 tapic lineDeallocateCall(MainCall:12074816) 0
58819 0 lineOpen(0) => 0
59109 0 Waiting for a call...
59400 0 lineOpen(0)LineHandle=12074920
When the prompt is played, we press '2' which should initiate a blind
transfer to extension 21, and this seems to be correctly interpreted by
Voice Guide. We listened in on the line and heard what sounded like a proper
flash hook followed by the DTMF tones, however the transfer was never
completed and again the PBX had to be reset. We adjusted the DTMF tones in
the Dialogic settings, so the timing shouldn't be a problem. The transfer
can be made using an analog phone plugged into the line, so the problem lies
somewhere in the Voice Guide/Dialogic end.
Any assistance in resolving this matter would be greatly appreciated.
Jeff Little
Medusa Research
I see in the trace that VoiceGuide plays the hookflash, followed by "21", and then it hangs up..
but the hookflash took a long time:
about 2.3 seconds.... (number at beginning of each line is a millisecond count)
and if a hookflash is set to such a long time then the PBX will just interpret this as a hangup and finish the call...
Its a bit surprising that the PBX has to be reset afterwards... have not seen this one before... maybe PBX becomes confused when it hears DTMF tones on a line which it thought it was hung up...
Anyway - I'd first try changing the length of your hookflash in the Dialogic configuration as it seems to be set too high, (what length does your PBX expect?)
What version of Dialogic's System Release drivers are you using (you should be using 5.01 or later).
We are using Dialogic's System Release 5.1.1.We have also set the hookflash time to 1 second.
Further testing revealed several interesting points:
VoiceGuide will successfully make transfers under two conditions:
1. The transfer node is set as the start node
2. The start node accesses the transfer node through a timeout function
However, if any digits are entered by the caller at any time, the PBX locks. The script continues to run, so VoiceGuide still correctly transmits DTMF tones to the PBX, but they are ignored.
Any assistance you could provide would be greatly appreciated.
Thanks!
Jeff Little
Medusa Research
Most PBXs require the hookflash to be in the 100ms range...
(a setting of "10" in the Dialogic's PBX configuration)
Have you confirmed what length hookflash your PBX requires?
If the hookflash is too long the PBX thinks that VoiceGuide has hung up the call...
