Query Database
I'm new to Interactive Voice Guide. I need some help...
I have an Access database called wireless.mdb, and in this database I have a table called 'subscribers'. I want Interactive Voice Guide to run a program if field name 'id' and 'mac' match the information given by the caller. I hope someone can help.
Thanks,
Adam.
You can use a query like this:
SELECT id, mac FROM subscribers WHERE id='$RV[GetId]' AND mac='$RV[GetMac]'
Where GetId and GetMac are names of VoiceGuide's Get Numbers modules.
Then see if the returned number of rows is 0 or 1. If 1 then an entry was found...
I'd recommend reading:
the section of the VoiceGuide Help file covering Result Variables,
the section of the VoiceGuide Help file covering Database Query module,
and also buying a book on databases and SQL
Thank you very much,
...your help is much apreciated.
I did look at your help files but I was still confused, I will think about buying a book if I wish to do more database work.
Thanks, once again.
Adam.
Y3000.com
