Audio File
On both incoming and broadcasting, instead of the expected audio, I get this message: "There has been an error playing this file, please check the file format."
What does file format mean? I can find nothing wrong.
All the sample scripts play ok, but not my simple script.
Any idea?
Hal Netkin
From VoiceGuide Help file:
Windows Voice Modem Wave driver can only support sound files in the following format PCM 8000Hz, 16bit, Mono. When using Voice modems all sound files must be recorded in the above format.
Dialogic Wave driver prefers sound files in the following format PCM 11025Hz, 8bit, Mono. When using a Dialogic card, all sound files should be recorded in the above format.
