Goto Voicemail Box Without Asking For Box Number
I am using the following script under a "Play Sound File"
On {0} Goto [Voicemail Box 9]
On {1} Goto [Voicemail Box 1]
On {2} Goto [Voicemail Box 2]
On {3} Goto [Voicemail Box 3]
On {4} Goto [Voicemail Box 4]
On {5} Goto [Voicemail Box 5]
On {6} Goto [bad Selection]
On {7} Goto [bad Selection]
On {8} Goto [Voicemail Box 8]
On {9} Goto [Voicemail Box 9]
On {*} Goto [Extention List]
On {#} Goto [Voicemail Retrieve]
On {Timeout 0} Goto [Hangup Now]
When I select a number (0-5, 8 or 9), the sytem again asks the caller to enter the voice mail box and enter the "#" key. I am trying to get it to go directly to the voicemail box without asking them again (really annoying).
I don't see any setup options under the voice mail box setup which would require this. Yes, all VMB are setup, have a welcoming voice message and are setup correctly
Here is the Log file:
70473 0 PlaySoundStart ok [E:\Inetpub\wwwroot\MenuSys\Voice\IVR\System29140100.wav]
70473 0 TimeoutClear
70483 0 RunModule PLAY end
70483 0 wa(14014,77041300)
79587 0 tapie monitordigits 49 2
79587 0 LsPlayMsg [1]
80067 0 PlaySoundStop ok
80077 0 TimeoutClear
80077 0 [Menu] Ask for Vmb Id
80137 0 PlaySoundStart ok [E:\PROGRA~1\ivg\system\voice\VmbAccessGetVmbId.wav]
The issue is the last 2 lines and I can't find anything in the help files....
HELP!!!
I had the same problem, your voice mailbox ID need to be at least 2 digits long for some reason. try 11, 12, 13, and so on.
Thanks! That fixed it...
Hey tech support guys - you should add this into your documentation.
