Comparing Rv In Vbs
#1 Maciej 25 November 2016 - 12:30 AM
Can You help me to create procedure
we use in pbx script:
vg.Bridge_Disconnect $RV[caller_lineid], $RV[agent1_line_id]
to disconnect caller and agent
after some steps we want to reconnect agent $RV[agent1_line_id] - active path - to client but we need to be sure that client is still connected
we need to compare $RV[session_id] on both lines using e.g.
sReturnValue = vg.RvGet($RV[SecondLineId], "$RV[session_id]")
IF caller_lineid $RV[session_id] = agent1_line_id $RV[agent1_line_id]
   THEN (
        vg.Script_Goto $RV[agent1_line_id], "path"
ELSE vg.Script_Goto $RV[agent1_line_id], "path"
END IF
#2 SupportTeam 27 November 2016 - 02:18 AM
Please see below. Please let us know if you have any questions:
sSessionCaller = vg.RvGet($RV[caller_lineid], "RV[session_id]")
sSessionAgent = vg.RvGet($RV[agent1_line_id], "RV[session_id]")
If sSessionCaller = sSessionAgent Then
  vg.Bridge_Connect $RV[caller_lineid], $RV[agent1_line_id]
Else
End If
set vg = Nothing
