Problems With Say Number Module
Here is the Event trace Log. You can see exactly what it is doing. I don't understand. Please help ASAP... Thanks.
Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\TimeTrack\}[scriptPath]{C:\TimeTrack}[$RV_STARTTIME]{9/29/2004 9:07:09 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Greet Caller]{1}[store Emp ID]{1001}[store Emp ID_PathTaken]{success}[Retrieve Emp In_RowCount]{1}[Retrieve Emp In_1_1]{8:10:00 AM}[Retrieve Emp In_2_1]{8}[Retrieve Emp In_3_1]{9/29/2004}
210731.45 0 rv replace end: [$RV[Retrieve Emp ID_3_1]
210731.46 0 [say Date Logged] Say numbers: [$RV[Retrieve Emp ID_3_1] as Date - MMDDYYYY
210731.46 0 fn PlaySoundStartNumbers [],[],[$RV[Retrieve Emp ID_3_1],Date - MMDDYYYY
210731.46 0 rv replace start: [$RV[Retrieve Emp ID_3_1]
210731.48 0 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\TimeTrack\}[scriptPath]{C:\TimeTrack}[$RV_STARTTIME]{9/29/2004 9:07:09 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Greet Caller]{1}[store Emp ID]{1001}[store Emp ID_PathTaken]{success}[Retrieve Emp In_RowCount]{1}[Retrieve Emp In_1_1]{8:10:00 AM}[Retrieve Emp In_2_1]{8}[Retrieve Emp In_3_1]{9/29/2004}
210731.48 0 rv replace end: [$RV[Retrieve Emp ID_3_1]
210731.55 0 sVbsFunctionToUse=DateMMDDYYYY
210731.63 0 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_0_SayNumber.vbs)
210731.73 0 cl Play_Start place$R.wav,monthV[.wav,0.wav
210731.73 0 File not found [place$R.wav]
210731.73 0 File not found [monthV[.wav]
210731.74 0 play set playid=175843
210731.79 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav,C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav,C:\Program Files\VoiceGuide\system\voice\0.wav]
210731.79 0 timer clear
-------- And when it tries the time......
210727.58 0 rv replace end: [8:10:00 AM]
210727.58 0 [say time In] Say numbers: [8:10:00 AM] as Time am/pm - HHNN
210727.58 0 fn PlaySoundStartNumbers [],[],[8:10:00 AM],Time am/pm - HHNN
210727.59 0 sVbsFunctionToUse=TimeHHNN
210727.63 0 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_0_SayNumber.vbs)
210727.72 0 cl Play_Start 60.wav,9.wav,,pm.wav
210727.72 0 play set playid=171828
210727.78 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\60.wav,C:\Program Files\VoiceGuide\system\voice\9.wav,C:\Program Files\VoiceGuide\system\voice\pm.wav]
210727.78 0 timer clear
-----------And when it tries a simple number......
210740.23 0 rv replace end: []
210740.23 0 [say Job Number] Say numbers: [] as Number
210740.23 0 fn PlaySoundStartNumbers [],[],[],Number
210740.25 0 sVbsFunctionToUse=Number
210740.28 0 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_0_SayNumber.vbs)
210740.38 0 cl Play_Start 0.wav
210740.38 0 play set playid=184453
210740.42 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\0.wav]
210740.42 0 timer clear
You're supplying the time to be said in different format then what you have specified in the - you have selected the Say Number module to speak a time supplied in format "HHNN" - but you are supplying the time in format "H:NN:SS AP/PM" - and looks like the say numbers script is getting a bit confused by that....
No number was supplied to say - so VoiceGuide says "zero"...
