Date And Time
I can't get VG to speak the correct date and time when pulling from a DB. The log shows that VG is retrieving the correct information but VG will not speak it. I have tried to tell it to speak it using both MSSQL format and HHNN format. I pull the information from two sperate fields. One is the Time and it retrieves it like 21:43 Neither format will speak it correctly and telling it to with the digits format makes it do very strange things. When I pull the date from a seperate field it VG retrieves it like 11/8/2004 but VG will not say it.
Please help
