Rv_lineid In Variable Name
I'm trying to get the evaluate module to use "X-$RV_LINEID" as the stored variable name, to help prevent inaccurate variables for multi lines so i can just call [GenericName-$RV_LINEID] to get the right value. but it doesn't seem to be working. Is it possible to create dynamic variable names like that? If not, what methods do you suggest for getting the job done?
Yes it is possible.
Can you post a sample script of what it is you are trying to do?
Also please keep in mind that there was a bug in v5.0 which prevented nested RVs - but v5.1 fixed this problem. (Registration codes issued for v5.0 work with v5.1)
i'm using 5.1. Is it also possible to use dynamic variable names in other module names, or is it just limited to eval's assign feature? script below.
test.vgs
From VoiceGuide Help file:
Where can Result Variables be used
You can use them just about anywhere. eg:
Specifying the 'trigger' and the destination modules in Paths leaving a module,
Filenames of sound files which are to be played or recorded,
What digits/dates/amounts are to be spoken to the caller in the Say Number module,
Looking up information in a database,
As parameters when calling other programs,
Evaluate Expression modules,
Send Email module: in destination Email address, Title, Message Body and Attachment Filename.
yes i've seen that. but i meant can i NAME a module, say a db module "DBMODULE-$RV_LINEID", and anytime i called it, i would call it with "goto [DBMODULE-$RV_LINEID]", so you'd never have to worry about getting results mixed from line to line. also did you look at the attached script? what i'm trying to do isn't working.
In your script you should evaluate expression:
$RV[Login]-$RV_LINEID
Then store result in a new RV - lets call it NewValue - so you should specify just NewValue in the "Assign result to following Result Variable" text box.
You can then us the new RV by specifying $RV[NewValue]
I'd suggest reading more of the Help file's sections on Result Variables and the various modules...
Yes.
eg: For line number 5 the module would have to be called "DBMODULE-5" and then the path "goto [DBMODULE-$RV_LINEID]" would take you to that module....
But why are you trying to have separate Database Query modules depending on LineID? You say:
Do you want to access different databases depending on which line the call came in on? If you need that then just use the $RV_LINEID as part of the SQL query to specify different databases or tables...
ah, that was right in front of my eyes, sorry. I'm worried about getting results mixed up because i built most of the script in the mindset of just having one line, and there's tons of database work and places where multiple callers would end up getting each others variables if the timing was right, so i'm trying to save some face. Thank you for your help, I'm sure I'll need it again.
Result Variables are not global - they are valid only for the line in which they were defined - you cannot get Result Variables 'mixed up' across different lines...
That doesn't give the desired effect. It creates NewValue and stores "XXXXX-#" in it, what i was trying to do is make the variable name $RV[Login-#], so from anywhere in the script i could just pull a $RV[Login-$RV_LINEID] and get back only the $RV[Login] contents i evaulated in the eval module. But that's alright, if getting other variables mixed up between lines isn't a possibility then it doesn't matter. Thanks for your time.
OK, I now see what you were trying to do.
Right now (v5.1) the contents of the "assign result to following Result Variable" text box do not get checked for having Result Variables as part of the name - whatever is there is taken to be the literal name of the new Result Variable.
There was never any need to use RVs when specifying a name of new RVs - but I'll pass this on to our programmers - someone may find a need for it and it doesn't hurt to have this option...
