Voice Files As Attachement In Email
Hello Support,
I configure the system to send me a message which a caller left in a mailbox.
Instead of getting 1 email, the system is sending me 2 emails. The emails are the same.
How can I stop this?
How can I configure this to send a message and exit ?
'Script : vmLm.vgs
'Module : VmLmMenu
iLineId = $RV_DEVICEID
sPathSysVoice = "$RV[PathSysVoice]"
sPathDataVm = "$RV[PathDataVm]"
sVmMsgCurr_Path = "$RV[PathDataVm]VmSave\"
sVmbId = "$RV[VmbId]"
sVmLmRec = "$RV[VmLmRec]"
set VG = CreateObject("VoiceGuide.CommandLink")
set Fso = CreateObject("Scripting.FileSystemObject")
'---+----1----+----2----+----3----+----4----+----5----+----6----+----7----+----8----+----9----+----0
select case "$RV_LastKeyPress"
case "$RV[Key_VmLmStopRecAndPlay]" '{1}
'Stop recording and play the recorded message
VG.Script_Goto iLineId, "", "VmLmRecPlay", ""
case "$RV[Key_VmLmDelRecRecAgain]" '{2}
'Delete the recorded message and start recording again
on error resume next
DeleteFile sVmLmRec
VG.Script_Goto iLineId, "", "VmLmStart", "[VmLmRec]{}" 'clear the name of the last recorded message
case "$RV[Key_VmLmSaveAndPlayGreeting]" '{3}
'Save the recorded message and play the greeting message for this voicemail box again
ProcessRecordedVmMsg iLineId, sVmbId, sVmLmRec
case "$RV[Key_VmLmDeleteGoGroupPrevious]" '{4}
'Delete the recorded message and group browse to the previous voicemail box
'and play it's greeting message
'todo
DeleteFile sVmLmRec
case "$RV[Key_VmLmDeleteAndPlayGreeting]" '{5}
'Delete the recorded message and play the greeting message for this voicemail box again
DeleteFile sVmLmRec
case "$RV[Key_VmLmDeleteGoGroupNext]" '{6}
'Delete the recorded message and group browse to the next voicemail box
'todo
DeleteFile sVmLmRec
case "$RV[Key_VmLmSaveGoVmLogin]" '{8}
'Save the recorded message and go to Voicemail Login Menu
VG.Script_Goto iLineId, "vmLogin.vgs", "VmLoginStart", "[VmLmRec]{}" 'clear the name of the last recorded message
case "$RV[Key_VmLmSaveVmExit]" '{0}
'Save the recorded message and exit the voicemail system
'return to wherever the return path was defined to.
VG.Script_Return iLineId, "[VmLmRec]{}" 'clear the name of the last recorded message
case "$RV[Key_VmLmSaveGoLmRecMsgMenu]" '{#}
'Stop recording and play the menu which speaks the options listed above
VG.Script_Goto iLineId, "", "VmLmMenuPlay", ""
case "timeout"
'only happens here after the "Max Rec Length" announcement is played
case else
'unknown - just play the menu then...
end select
Set VG = Nothing
set Fso = Nothing
sub ProcessRecordedVmMsg(iLineId, sVmbId, sVmLmRec)
if sVmLmRec = "" then
exit sub
end if
if (FileMoreThenMinLength(sVmbId, sVmLmRec)) then
VG.Vm_Event iLineId, "FORWARD", sVmbId, sVmLmRec, "", ""
else
VG.Admin_TraceLogAdd iLineId, 2, "vm msg too short, deleting: " & sVmLmRec
DeleteFile sVmLmRec
end if
end sub
function FileMoreThenMinLength(sVmbId, sFilename)
if "$RV[VmLmRec_RecLen100ms]" = "" then
'[VmLmRec_RecLen100ms] not set...
VG.Admin_TraceLogAdd iLineId, 1, "vm RV[VmLmRec_RecLen100ms] not set."
FileMoreThenMinLength = True
exit function
end if
iRecLen100ms = Clng($RV[VmLmRec_RecLen100ms])
iFileLength = iRecLen100ms / 10
iMinLength = Cint(VG.Vm_VmbConfig_Get(sVmbId, "MsgLenMin"))
if iMinLength = "" then
'min length undefined - return true
exit function
end if
if iFileLength >= iMinLength then
else
VG.Admin_TraceLogAdd iLineId, 2, "vm SoundFileLength=" & iFileLength & ", MsgLenMin=" & iMinLength
FileMoreThenMinLength = False
end if
end function
sub DeleteFile(sFname)
'starts a VBScript which is designed to make repeated attempts to delete the file.
Set ws = CreateObject("WScript.Shell")
ws.run "wscript ""$RV[PathVgSys]vm\vm_deletefile.vbs"" """ & sFname & """", 0
Set ws = Nothing
end sub
Regards
Did you modify the vmLm.vgs script?
Setting the forwarding email can be done from the Voicemail Configuration Manager application. You can specify the forwarding email addresses to be associated with each voicemail box and VoiceGuide will read the email addresses from that config file and send the emails.
If you made changes to the vmLm.vgs script then you should restore the original scripts and just use the currently built-in email sending mechanism.
If you are using the original vmLm.vgs files and are still having 2 emails sent then double check the settings for that voicemail box. eg. Is it forwarding recordings to other voicemail boxes?
No, I can't remember if I did. I don't think so.
I did a research and I find out that:
When you press 1, the system is replaying the message
When you press 2, the system is recording the message again
When you press 3, the system is saving the message
BUT:
after the system recorded the message the system is going back to a point to record a message.
If you hang up, the system is still recording the message and the message will be send to your mail.
I am using the original vmlm.vgs file and I am still having 2 emails.
The system also sends 2 emails to an other email address which I specified.
I can be wrong, but I think that the second email which the system is sending is the one that is still recording after you hang up the telephone.
Question:
1) How can this problem fixed?
Regards
Could you please post a copy of VoiceGuide's Trace Logs which capture the call, this will allow us to see what happened.
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=10
Trace shows voicemail message recording was stopped by the key # being pressed:
170555.33 8 dtmf # (66390,35,2)
and the voicemail scripts then went onto [VmLmMenuPlay] module which plays RecMsgMenu.wav file:
170555.55 8 state [VmLmMenuPlay] Playing
170555.59 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\RecMsgMenu.wav]
The key 3 is then pressed :
170603.03 8 dtmf 3 (66390,51,2)
Which results in the voicemail system/scripts "Saving the recorded message and play the greeting message for this voicemail box again" - as per the specifications. See: http://www.voiceguide.com/vghelp/html/voicemailMenus.htm
So the recorded voicemail message gets forwarded:
170603.27 8 vm frwrd vmb 0001 email to 107@tocmail.com (wav attached)
And the voicemail system plays the welcoming message for the voicemil box 0001 again and then again starts recording:
170606.80 8 state [VmLmRec] Recording
Once that recording completes the new recorded message then gets forwarded as well:
170609.23 8 vm frwrd vmb 0001 email to 107@tocmail.com (wav attached)
If you looked at the emails received you would see that the two emails have different sound files attached to them...
So in summary, the system is sending two emails as caller has selected to record two messages...
If caller has not pressed the 3 key then it looks like the telephony device you are using has mistakenly detected the "3" while playing the RecMsgMenu.wav sound file...
(As a temporary solution for false detections you could try re-recording the RecMsgMenu.wav sound file.)
