Sending Out Fax's From Voiceguide
I have seen many post on how to receive fax but how do you send out a fax from voice guide.
Any programs recommended?
Any vbs code that you may offer?
Thanks,
-Brandon
p.s. Voice guide is an excellent program. I have recommended it to many corporations.
From VG Help file, Run VBScript module section:
Example 6:
The VB Script below will fax out a Word document "c:\info\prices1.doc" to fax number 5554321. Note: WinFax or another scriptable faxing agent is needed in order for the script below to work.
Dim WordApp
Dim myWordDoc
Dim strPathDoc
Dim intRecord
Set WordApp = CreateObject("word.application")
WordApp.Visible = True
strPathDoc = "c:\info\prices1.doc"
Set myWordDoc = WordApp.Documents.Open(strPathDoc)
myWordDoc.ActiveWindow.Document.SendFax("5554321")
'always deallocate after use...
Set myWordDoc = Nothing
Set WordApp = Nothing
Example 7:
This example builds on previous example by using Result Variables in the VB Script. The example below uses values entered by the caller in the 'Get Fax Number' and 'Select Price List' Get Number modules. The two result variables will be replaced with their actual values before the VB Script is run.
Dim WordApp
Dim myWordDoc
Dim strPathDoc
Dim intRecord
strPathDoc = "c:\info\prices$RV[select Price List].doc"
myWordDoc.ActiveWindow.Document.SendFax("$RV[Get Fax Number]")
Example 8:
The VB Script below will fax out a document "c:\info\prices1.doc" to all the fax numbers contained in the FaxDb database. Values could have been inserted into this database using the DB Query module.
Dim WordApp      'Object
Dim myWordDoc    'Word.Document
Dim strPathDoc  'String
Dim myRST        'Recordset
Dim myDB        'Database
Dim strFaxNumber 'String
Dim intRecord    'Long
Set myDB = DBEngine.Workspaces(0).Databases(0)
Set myRST = myDB.OpenRecordset("FaxDb", dbOpenDynaset)
myRST.MoveLast
For intRecord = myRST.RecordCount To 1 Step -1
    strFaxNumber = CStr(myRST.Fields(1))
    myWordDoc.ActiveWindow.Document.SendFax(strFaxNumber)
    myRST.MovePrevious
Next intRecord
myRST.Close
Set myRST = Nothing
Set myDB = Nothing
When I run example 6 I get the following error at line 10
"Microsoft Mail Local Fax is not installed on your system." Source is Microsoft Word
Can you point me in the right direction.
I can send faxes from Word with no issues.
Thanks again for all of the help.
-Brandon
from the description of the examples quoted above:
BTW, where from I can get "WinFax or another scriptable faxing agent"? And why Microsoft Local Fax is in the error? Is this WinFax or Microsoft Local Fax is free?
Sameers
