Announced Transfer Problems
Hi I have had an announced transfer module working fine for the last few weeks. For some reason it has stopped working without changing anything on the system. Now when you hit the key that transfers the call to another number you hear the numbers dial and the announced transfer message... I believe this is a problem with the hook flash. The hook flash is on a setting of 5 in the dialogic TSP settings. I increased it to 10 with no effect. The logs are below. Any suggestions are welcomed
144216.63 7 linedevstate 2048 0 0
144216.63 7 callstate OFFERING 65894 0 4
144216.63 7 Lev_CallerID [0293318320,]
144216.64 7 callinfo CALLEDID
144216.64 7 callinfo ORIGIN
144216.64 7 ring 0
144222.63 7 ring 2
144222.63 7 No old processes from last call (could not obtain handle) 880, 0
144222.63 7 Answer the call at 9/11/2004 2:42:22 PM
144222.63 7 lineAnswer(65894) => 65877
144223.17 7 callstate CONNECTED 65894,1,0
144223.17 7 WorkingModeTAPI@Connected=
144223.17 7 WorkingModeScript@Connected=
144223.17 7 Inband detection not enabled
144223.17 7 StartLoadedVgs at 9/11/2004 2:42:23 PM
144223.17 7 AddRVns [scriptsPath]{C:\BookingAngel\}
144223.17 7 rv add [$RV_STARTTIME]{9/11/2004 2:42:23 PM}
144223.19 7 rv add [$RV_DEVICEID]{7}
144223.19 7 rv add [$RV_CIDNAME]{}
144223.19 7 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
144223.19 7 rv add [$RV_CIDNUMBER]{0293318320}
144223.19 7 tapi Reply (LineEvReply) ok 65877 0
144223.19 7 callinfo MONITORMODES
144223.19 7 TimeoutClear
144223.19 7 [intro Message] Playing
144223.19 7 tts generate start[Hi, You have reached the offices of booking angel. To hear a demonstration of the booking angel service press 1, for sales enquiry's press 2, If you are a restaurant ringing to inform us of a cancellation press 3, For all other inquiries press 4]
144223.19 7 tts generate wait
144223.19 7 RunModule PLAY end
144223.41 7 tts generate finish
144223.41 7 [intro Message] Playing (C:\Program Files\VoiceGuide\data\tts7.wav)
144223.42 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts7.wav]
144223.42 7 TimeoutClear
144223.42 7 wa(16524,24712500)
144223.42 7 callinfo MONITORMODES
144227.94 7 dtmf 4 (65894,52,2)
144227.94 7 ScriptEventCode 52 iLineState=1100
144227.94 7 LsPlayMsg 4
144228.00 7 PlaySoundStop err=0
144228.00 7 rv add [intro Message]{4}
144228.00 7 TimeoutClear
144228.00 7 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
144228.38 7 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
144228.38 7 ScriptEventCode 9012 iLineState=1900
144228.38 7 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
144228.38 7 TimeoutSet 45 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
144228.38 7 [Transfer Dean] Announced Conference to ,0414421978 (Generate)
144228.38 7 tapic lineGenerateDigits(65894,!,0) => 0
144228.63 7 generate LINEGENERATETERM_DONE
144228.64 7 TimeoutSet 1 EV_TAPI_GENERATE
144229.69 7 Timer fired EV_TAPI_GENERATE
144229.69 7 ScriptEventCode 9602 iLineState=1900
144229.69 7 LsXferStart EV_TAPI_GENERATE
144229.69 7 TimeoutSet 1 EV_HOOKFLASHFINISHED
144230.78 7 Timer fired EV_HOOKFLASHFINISHED
144230.78 7 ScriptEventCode 9200 iLineState=1905
144230.78 7 LsXferPlayVts EV_HOOKFLASHFINISHED
144230.78 7 tapic lineGenerateDigits(65894,,0414421978,0) => 0
144234.25 7 generate LINEGENERATETERM_DONE
144234.25 7 TimeoutSet 1 EV_TAPI_GENERATE
144235.27 7 Timer fired EV_TAPI_GENERATE
144235.27 7 ScriptEventCode 9602 iLineState=1905
144235.27 7 LsXferPlayVts EV_TAPI_GENERATE
144235.27 7 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, 0293318320, Digits
144235.27 7 sVbsFunctionToUse=Digits
144235.28 7 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_7_SayNumber.vbs)
144235.30 7 cl Play_Start C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,0.wav,2.wav,9.wav,3.wav,3.wav,1.wav,8.wav,3.wav,2.wav,0.wa
,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav
144235.33 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program Files\VoiceGuide\system\voice\0.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\9.wav,C:\Program Files\VoiceGuide\system\voice\3.wav,C:\Program Files\VoiceGuide\system\voice\3.wav,C:\Program Files\VoiceGuide\system\voice\1.wav,C:\Program Files\VoiceGuide\system\voice\8.wav,C:\Program Files\VoiceGuide\system\voice\3.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\0.wav,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav]
144235.33 7 TimeoutClear
144235.33 7 wa(14701,25901511)
144235.33 7 callinfo MONITORMODES
144250.09 7 Play End line[7] (id=259015)
144250.09 7 ScriptEventCode 8001 iLineState=1906
144250.09 7 LsXferPlayAnn EV_PLAY_FINISHED
144250.09 7 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
144250.09 7 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, 0293318320, Digits
144250.11 7 sVbsFunctionToUse=Digits
144250.11 7 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_7_SayNumber.vbs)
144250.14 7 cl Play_Start C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,0.wav,2.wav,9.wav,3.wav,3.wav,1.wav,8.wav,3.wav,2.wav,0.wa
144250.16 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program Files\VoiceGuide\system\voice\0.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\9.wav,C:\Program Files\VoiceGuide\system\voice\3.wav,C:\Program Files\VoiceGuide\system\voice\3.wav,C:\Program Files\VoiceGuide\system\voice\1.wav,C:\Program Files\VoiceGuide\system\voice\8.wav,C:\Program Files\VoiceGuide\system\voice\3.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\0.wav,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav]
144250.16 7 TimeoutClear
144250.16 7 wa(14701,27385911)
144250.17 7 callinfo MONITORMODES
144253.03 7 callstate DISCONNECTED 65894,0,0
144253.03 7 ScriptEventCode 9250 iLineState=1906
144253.03 7 LsXferPlayAnn EV_REMOTEPARTY_DISCONNECT
144253.03 7 TimeoutSet 1 EV_PLAY_FINISHED
144253.09 7 PlaySoundStop err=0
144254.11 7 Timer fired EV_PLAY_FINISHED
144254.11 7 ScriptEventCode 8001 iLineState=1906
144254.11 7 LsXferPlayAnn EV_PLAY_FINISHED
144254.11 7 tapic lineGenerateDigits(65894,!,,,1,0) => LINEERR_INVALCALLSTATE [8000001C]
144254.11 7 rv add [Hangup Time]{9/11/2004 2:42:54 PM}
144254.11 7 Hanging up call... [lineGenerateDigits ret=-2147483620]
144254.11 7 RecSoundStop ok
144254.11 7 PlaySoundStop err=0
144254.11 7 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
144254.11 7 fnHangupCall end
144254.16 7 linedevstate 2048 0 0
144254.16 7 callstate IDLE 65894 0 0
144254.16 7 WorkingMode@Idle=
144254.16 7 TimeoutClear
144254.16 7 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
144254.16 7 tapi Reply (LineEvReply) ok 65809 0
144255.20 7 Timer fired EV_TIMEOUT_TIMETOREINITLINE
144255.20 7 ScriptEventCode 9008 iLineState=900
144255.20 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
144255.20 7 ReinitTelephony due to IDLE
144255.20 7 tapic lineDeallocateCall(MainCall:65894) 0
144255.30 7 lineOpen(7)=>
144255.30 7 Waiting for a call...
144255.30 7 LineHandle=65792
144255.30 7 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
144258.58 7 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
144258.58 7 ScriptEventCode 9013 iLineState=900
Also to restart the dialogic system withough restarting the computer do I just open the dialogic configuration manager and use the red and green buttons to start and stop... I seem to get an error when I re-start using this method.. If you know of the proper way to do it would appreciate it as restarting our server all the time is a problem
Your hookflash is too short... if using Dialogic's TAPI config screens does not work for you try using the '.PRM approach', see: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm
The green/red buttons in the Dialogic DCM should be working with no problems - not too sure why this has stopped working for you as well - but it does look like both problems seem to have occurred at same time... are you sure nothing else got installed on this system?
Team,
I am having exact same issue as deanm.
I am running XP
Enterprise 4 line with dialer
proline 2v dialogic card
I tried to fix issue by deinstalling and reinstalling dialogic software 5.1.1 and sp1 then went back down to 5.01 which was working. Deinstalled and went down to voiceguide 5.1.7 (still did not work) went back up to 5.2.3a.
I have changed the configuration settings in the control panel (modem section) from 50 to 100 on flash time. It made no difference. I then went into the configuration file of vg and took out the rem ; and changed the figures for flash time. Still no difference.
;"TAPI" : TAPI functions calls are made to driver to action transfers and conferences.
;"Generate" : exlilicit tones and signals are generated using TAPI calls
;"AT" : modem AT commands are used
TransferControl_Modem=Generate
TransferControl_TelBoards=TAPI
;Preferred Lengths of hookflash and DTMF tones.
;will be used if Generate method is selected. In milliseconds.
;If commented out then the default settings for the device will be used.
;Note: Dialogic cards will ignore this setting and use what is in the Dialogic TSP Configuration settings.
DurationHookflash=1000
;DurationDtmfTone=100
Any thoughts of what I should do next?
Here is a portion of the event log.
111021.53 7 timer clear
111021.55 7 wa(7278,28390911)
111021.57 7 callinfo MONITORMODES
111028.86 7 play end current play (playid=283909)
111028.88 7 ScriptEventCode 8001 iLineState=1600
111028.89 7 LsSayNbrPlay EV_PLAY_FINISHED
111028.91 7 timer set 10 EV_TIMEOUT_HANGUP
111028.93 7 timer set 0 EV_TIMEOUT_GOTOMODULE
111028.94 7 ScriptEventCode 9002 iLineState=1600
111028.96 7 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
111028.98 7 timer clear
111029.01 7 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
111029.38 7 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
111029.39 7 ScriptEventCode 9012 iLineState=1900
111029.41 7 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
111029.43 7 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
111029.45 7 [Transfer Call Investor Pro] Announced Conference to 7792940 (TAPI)
111029.46 7 fn SrSetupConferenceTapi
111029.48 7 [Transfer Call Investor Pro] Number: 7792940
111029.53 7 lineSetupConference(65638,65689,0,0) in SrSetupConferenceTapi => 65604
111031.55 7 tapi Reply (LineEvReply) ok 65604 0
111031.57 7 callstate CONFERENCED 65638 0 0
111031.59 7 linedevstate 2048 0 0
111031.61 7 callstate DIALTONE 66492 2 0
111031.64 7 lineDial(66492,7792940) => 66475
111031.65 7 linedevstate 2048 0 0
111031.68 7 callstate ONHOLDPENDCONF 65553 0 0
111031.70 7 callstate DIALING 66492 0 0
111031.71 7 callstate PROCEEDING 66492 0 0
111031.72 7 callinfo CALLEDID
111039.93 7 callstate CONNECTED 66492 1 0
111039.95 7 callstate CONNECTED 66492,1,0
111039.96 7 WorkingModeTAPI@Connected=SetupConferenceAnnounced
111039.98 7 WorkingModeScript@Connected=
111039.00 7 lineMonitorDigits(66492) => 0
111040.02 7 fn PlaySoundStartNumbers [TsfrCallFrom.wav],[TsfrAskAccept.wav],[6186679930],Digits
111040.05 7 sVbsFunctionToUse=Digits
Thanks,
-Brandon Crockett
I have had this problem for a long time and have recently upgraded to the dialogic version of voice guide in hope that it will fix the problem.
I have edited the TAPI settings of the hook flash and experimented with different times without success.
I have edited the PRM file in the dialogic DCM settings. I was curious how the system knows to look at one over the other. If they both do the same system how do you stipulate that the system should look at the PRM file versus the TAPI settings
My modem is the D41JCT, I have selected Country as Australia / New Zealand so the relevant file is an_41j.prm
I restarted the dialogic service after changing the file setting from 5 to 10. Incidentally none of the paramters were commented out with a #, which is why I asked the earlier question about how the system knows when to read PRM settings versus TAPI
My most recent log is pasted below
010935.52 3 tw lev_CallerID [0293318320,,]
010935.52 3 rv clear all
010935.52 3 init LineState ResetAtStartOfNewCall.
010935.52 3 No old processes from last call (could not obtain handle) 2024, 0
010935.52 3 answer the call
010935.52 3 timer clear
010935.53 3 event callstate OFFERING 3 0 0
010935.53 3 script interpretor: VgMulti v6.0.1049
010935.53 3 init LineState ResetAtStartOfNewCall.
010935.53 3 dont answer yet, wait for CallerID information.
010935.53 3 tw ring 1
010935.53 3 ring time since last ring (ms): 0
010935.53 3 rv clear all
010935.53 3 answer the call
010935.53 3 timer clear
010935.58 3 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
010935.58 3 event TDX_CST, code=134, state=6001
010936.06 3 event callstate CONNECTED 3 0 0
010936.06 3 WorkingModes tapi= script=
010936.06 3 Inband detection not enabled
010936.06 3 StartLoadedVgs at 11/10/2005 1:09:36 AM
010936.06 3 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState
010936.06 3 set sScriptToRunOnHangup=[] in StartLoadedVgs
010936.06 3 rv add [$RV_STARTTIME]{11/10/2005 1:09:36 AM}
010936.06 3 rv add [$RV_DEVICEID]{3}
010936.06 3 rv add [$RV_CIDNAME]{}
010936.08 3 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
010936.08 3 rvns add [scriptsPath]{C:\BookingAngel\}
010936.08 3 rv add [$RV_CIDNUMBER]{}
010936.08 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
010936.08 3 event TDX_SETHOOK, code=135, state=6001
010936.08 3 timer clear
010936.08 3 state [intro Message] Playing
010936.08 3 tts generate start[Hi, You have reached the offices of booking angel. To hear a demonstration of the booking angel service press 1, for sales press 2, If you are a restaurant ringing about a booking or cancellation press 3, For all other inquiries press 4]
010936.08 3 tts generate wait
010936.27 3 tts generate finish
010936.27 3 state [intro Message] Playing (C:\Program Files\VoiceGuide\data\tts3.wav)
010936.27 3 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts3.wav
010936.27 3 timer clear
010936.34 3 tw wav->vox convert end 45984,C:\Program Files\VoiceGuide\data\tts3.vox,1,0,,
010936.36 3 play start ok, lPlayId=46062
010943.44 3 tw dtmf 2 (3,50,50)
010943.44 3 event 2, code=50, state=1100
010943.44 3 LsPlayMsg 2,2
010943.44 3 play PlaySoundStop ok
010943.44 3 rv add [intro Message]{2}
010943.44 3 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
010943.45 3 event TDX_CST, code=134, state=6001
010943.45 3 tw PlayEnd 3 46062
010943.45 3 play end id=46062, (current ID)
010943.45 3 event EV_PLAY_FINISHED, code=8001, state=6001
010943.45 3 tw DialogicEvent 129,TDX_PLAY,46062,0,0,,,
010943.45 3 event TDX_PLAY, code=129, state=6001
010943.45 3 timer clear
010943.45 3 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
010943.89 3 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
010943.89 3 event EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
010943.89 3 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
010943.89 3 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
010943.89 3 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec)
010943.89 3 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
010943.89 3 state [Transfer Dean] Announced 3-Way Conference to 0414421978
010953.00 3 tw PlayEnd 3 0
010953.00 3 play end id=0, (old ID) current id=46062
010953.00 3 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
010953.00 3 event TDX_DIAL, code=132, state=1902
010953.00 3 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
010953.00 3 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
010953.00 3 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
010955.16 3 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
010955.16 3 event EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
010955.16 3 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
010955.16 3 Dial(0414421978, cp on) call
010955.16 3 Dial(0414421978) ok
010955.16 3 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
011017.58 3 tw DialogicEvent 133,TDX_CALLP,9,0,0,CR_NORB,,
011017.58 3 event TDX_CALLP, code=133, state=1903
011017.58 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,TDX_CALLP,9,0,0,CR_NORB,,
011017.58 3 xfer dial !,,,1
011027.97 3 timer fired EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
011027.97 3 event EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG, code=9021, state=1906
011027.97 3 LsXfer_5B : 9021(EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG),EV_TIMEOUT_ANNOUNCED_T
ANSFER_ATTEMPT_TOOK_TOO_LONG,0,0,0,,,
011031.28 3 tw PlayEnd 3 0
011031.30 3 play end id=0, (old ID) current id=46062
011031.30 3 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
011031.30 3 event TDX_DIAL, code=132, state=1906
011031.30 3 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,,
011031.30 3 sXferDialResult_SuccOrFail=
011031.30 3 path {CR_NORB} not found
011031.30 3 path {noringback} not found
011031.30 3 going down False path (iXferType=23) state:LsXferCallRejected
011031.30 3 timer clear
011031.30 3 state [No Connection] Playing
011031.30 3 tts generate start[We are experiencing larger than expected call volumes. Please leave a message after the beep including your name and contact telephone number and one of the booking angel team will contact you shortly.]
011031.30 3 tts generate wait
011031.45 3 tts generate finish
011031.47 3 state [No Connection] Playing (C:\Program Files\VoiceGuide\data\tts3.wav)
011031.47 3 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts3.wav
011031.47 3 timer clear
011031.53 3 tw wav->vox convert end 101187,C:\Program Files\VoiceGuide\data\tts3.vox,1,0,,
011031.53 3 play start ok, lPlayId=101250
011043.80 3 tw PlayEnd 3 101250
011043.81 3 play end id=101250, (current ID)
011043.81 3 event EV_PLAY_FINISHED, code=8001, state=1100
011043.81 3 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
011043.81 3 path {EV_PLAY_FINISHED} not found
011043.81 3 timer set 10 EV_TIMEOUT_HANGUP
011043.81 3 timer set 0 EV_TIMEOUT_GOTOMODULE
011043.81 3 event EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
011043.81 3 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
011043.81 3 path {EV_TIMEOUT_GOTOMODULE} not found
011043.81 3 tw DialogicEvent 129,TDX_PLAY,101250,0,0,,,
011043.81 3 event TDX_PLAY, code=129, state=6001
011043.81 3 timer clear
011043.81 3 state [Message] Recording
011043.81 3 rv replace start: [\Feedback\$RV_CIDNUMBER_$RV_STARTTIME]
011043.81 3 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{11/10/2005 1:09:36 AM}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\BookingAngel\}[$RV_CIDNUMBER]{}[intro Message]{2}
011043.83 3 rv replace end: [\Feedback\_11/10/2005 1:09:36 AM]
011043.83 3 rv add [Message]{\Feedback\_11/10/2005 1:09:36 AM}
011043.83 3 RecSoundStart [\Feedback\_11/10/2005 1:09:36 AM] call
011043.83 3 state [Message] Recording \Feedback\_11/10/2005 1:09:36 AM
011043.83 3 RecSoundStart err[dlgc dx_fileopen(strFname=\Feedback\_11/10/2005 1:09:3.vox) => -1, [dx_fileerrno=2, ENOENT, No such file or directory; invalid device name; file or path not found.]]
011043.83 3 rv add [Hangup Time]{11/10/2005 1:10:43 AM}
011043.83 3 state Hanging up call...
011043.83 3 HangupCall_Common hCall=3
011043.84 3 rec RecSoundStop ok
011043.84 3 play PlaySoundStop ok
011043.84 3 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
011043.84 3 fnHangupCall end
011043.84 3 timer set 90 EV_TIMEOUT_GOTOMODULE
011043.84 2 event EV_REC_FINISHED, code=8003, state=0
011043.89 3 event callstate IDLE 3 0 0
011043.89 3 WorkingMode@Idle=
011043.89 3 timer clear
011043.89 3 rec RecSoundStop ok
011043.89 3 play PlaySoundStop ok
011043.89 3 rv add [CallEndTime]{11/10/2005 1:10:43 AM}
011043.89 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
011043.89 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
011043.89 3 event TDX_SETHOOK, code=135, state=900
011043.89 3 LsAwaitingCalls EV_UNKNOWN_135
011044.94 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
011044.94 3 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
011044.94 3 init atidle reinit : start
011044.94 3 init atidle reinit iConferenceOtherLegLid=-1
011044.94 3 init atidle reinit : reset all LineState variables
011044.94 3 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
011044.94 3 state Waiting for a call...
011045.27 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
011045.27 3 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
When using VoiceGuide for Dialogic the hookflash length is set in Config.xml file. The Config.xml file is located in VoiceGuide's \data\ subdirectory. The following section of Config.xml should be edited:
<SetParm>
<Description>Flash time during dialing</Description>
<Key>DXBD_FLASHTM</Key>
<Value>10</Value>
<Default>10</Default>
</SetParm>
Setting is in 10ms units. A value of 10 represents 100ms.
I have managed to almost fix the problem. Turned out to be a Telstra problem. They decided to disable 3 way calling on 2 of our phone lines !!!! How frustrating.
Problem is now it does the transfer, calls the third party, then when the third party hears the message and press 1 to accept the call it wont connect the calls. It puts both parties on hold, then drops one of the calls.
It does the same if you reject the call.
Also I wanted to put the caller ID ($RV_CIDNUMBER) in the Text to speech message played to the third party when accepting the call. I inserted the above variable in the text file and its not working. Is it another setting in the config.xml file to trun on caller ID or do you do it in the voice guide line device congif. HAve tried the line device config
Log is below.
220514.19 3 event callstate OFFERING 3 0 0
220514.19 3 script interpretor: VgMulti v6.0.1049
220514.19 3 init LineState ResetAtStartOfNewCall.
220514.19 3 dont answer yet, wait for CallerID information.
220514.19 3 tw ring 1
220514.19 3 ring time since last ring (ms): 0
220514.19 3 rv clear all
220514.19 3 answer the call
220514.19 3 timer clear
220514.20 3 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
220514.20 3 event TDX_CST, code=134, state=6001
220514.73 3 event callstate CONNECTED 3 0 0
220514.73 3 WorkingModes tapi= script=
220514.75 3 Inband detection not enabled
220514.75 3 StartLoadedVgs at 12/10/2005 10:05:14 PM
220514.75 3 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState
220514.75 3 set sScriptToRunOnHangup=[] in StartLoadedVgs
220514.75 3 rv add [$RV_STARTTIME]{12/10/2005 10:05:14 PM}
220514.75 3 rv add [$RV_DEVICEID]{3}
220514.75 3 rv add [$RV_CIDNAME]{}
220514.75 3 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
220514.75 3 rvns add [scriptsPath]{C:\BookingAngel\}
220514.75 3 rv add [$RV_CIDNUMBER]{}
220514.75 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
220514.75 3 event TDX_SETHOOK, code=135, state=6001
220514.75 3 tw DialogicEvent 134,TDX_CST,60047,0,0,DE_LCON,,
220514.75 3 event TDX_CST, code=134, state=6001
220514.75 3 timer clear
220514.75 3 state [intro Message] Playing
220514.75 3 tts generate start[Hi, You have reached the offices of booking angel. To hear a demonstration of the booking angel service press 1, for sales press 2, If you are a restaurant ringing about a booking or cancellation press 3, For all other inquiries press 4]
220514.77 3 tts generate wait
220514.94 3 tts generate finish
220514.95 3 state [intro Message] Playing (C:\Program Files\VoiceGuide\data\tts3.wav)
220514.95 3 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts3.wav
220514.95 3 timer clear
220515.00 3 tw wav->vox convert end 784671,C:\Program Files\VoiceGuide\data\tts3.vox,1,0,,
220515.02 3 play start ok, lPlayId=784718
220524.58 3 tw dtmf 2 (3,50,50)
220524.58 3 event 2, code=50, state=1100
220524.58 3 LsPlayMsg 2,2
220524.58 3 play PlaySoundStop ok
220524.59 3 rv add [intro Message]{2}
220524.59 3 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
220524.59 3 event TDX_CST, code=134, state=6001
220524.59 3 tw PlayEnd 3 784718
220524.59 3 play end id=784718, (current ID)
220524.59 3 event EV_PLAY_FINISHED, code=8001, state=6001
220524.59 3 tw DialogicEvent 129,TDX_PLAY,784718,0,0,,,
220524.59 3 event TDX_PLAY, code=129, state=6001
220524.59 3 timer clear
220524.59 3 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
220525.02 3 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
220525.02 3 event EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
220525.02 3 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
220525.02 3 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
220525.02 3 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec)
220525.02 3 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
220525.02 3 state [Transfer Dean] Announced 3-Way Conference to 0414421978
220525.27 3 tw PlayEnd 3 0
220525.27 3 play end id=0, (old ID) current id=784718
220525.27 3 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
220525.27 3 event TDX_DIAL, code=132, state=1902
220525.27 3 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
220525.27 3 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
220525.28 3 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
220527.42 3 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
220527.42 3 event EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
220527.42 3 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
220527.42 3 Dial(0414421978, cp on) call
220527.42 3 Dial(0414421978) ok
220527.42 3 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
220536.83 3 tw DialogicEvent 134,TDX_CST,200,0,0,DE_TONEON,TID_RNGBK2,
220536.83 3 event RINGBACK, code=134, state=1903
220536.83 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,RINGBACK,200,0,0,DE_TONEON,TID_RNGBK2,
220536.83 3 event TID_RNGBK2, code=134, state=1903
220536.83 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TID_RNGBK2,200,0,0,DE_TONEON,TID_RNGBK2,
220536.83 3 event TDX_CST, code=134, state=1903
220536.83 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TDX_CST,200,0,0,DE_TONEON,TID_RNGBK2,
220539.19 3 tw DialogicEvent 133,TDX_CALLP,10,3,0,TDX_CALLP,CR_CNCT,CON_PVD
220539.19 3 event CON_PVD, code=133, state=1903
220539.19 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CON_PVD,10,3,0,CR_CNCT,CON_PVD,CON_PVD
220539.20 3 event TDX_CALLP, code=133, state=1903
220539.20 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,TDX_CALLP,10,3,0,CR_CNCT,CON_PVD,CON_PVD
220539.20 3 LsXfer_3 CR_CNCT on an XT_3WAY_ANNOUNCED
220539.20 3 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
220539.20 3 path {EV_PLAY_FINISHED} not found
220539.20 3 LsXfer_4_PlayAnn : 9005(EV_TIMEOUT_REPLAYMSG),EV_TIMEOUT_REPLAYMSG,0,0,0,,,
220539.20 3 path {EV_TIMEOUT_REPLAYMSG} not found
220539.20 3 rv replace start: [This is a transferred call. Caller I.D $RV_CIDNUMBER Press 1 to accept the call or any other number to reject it ]
220539.20 3 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{12/10/2005 10:05:14 PM}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\BookingAngel\}[$RV_CIDNUMBER]{}[intro Message]{2}
220539.22 3 tts generate start[This is a transferred call. Caller I.D Press 1 to accept the call or any other number to reject it ]
220539.22 3 tts generate wait
220539.30 3 tts generate finish
220539.30 3 state [Transfer Dean] Playing (C:\Program Files\VoiceGuide\data\tts3.wav)
220539.30 3 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts3.wav
220539.30 3 timer clear
220539.34 3 tw wav->vox convert end 809015,C:\Program Files\VoiceGuide\data\tts3.vox,1,0,,
220539.36 3 play start ok, lPlayId=809062
220546.23 3 tw PlayEnd 3 809062
220546.23 3 play end id=809062, (current ID)
220546.23 3 event EV_PLAY_FINISHED, code=8001, state=1904
220546.23 3 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
220546.23 3 path {EV_PLAY_FINISHED} not found
220546.23 3 LsXfer_4_PlayAnn : 9005(EV_TIMEOUT_REPLAYMSG),EV_TIMEOUT_REPLAYMSG,0,0,0,,,
220546.23 3 path {EV_TIMEOUT_REPLAYMSG} not found
220546.23 3 tw DialogicEvent 129,TDX_PLAY,809062,0,0,,,
220546.23 3 event TDX_PLAY, code=129, state=1904
220546.25 3 LsXfer_4_PlayAnn : 129(EV_UNKNOWN_129),TDX_PLAY,809062,0,0,,,
220546.25 3 path {TDX_PLAY} not found
220546.25 3 rv replace start: [This is a transferred call. Caller I.D $RV_CIDNUMBER Press 1 to accept the call or any other number to reject it ]
220546.25 3 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{12/10/2005 10:05:14 PM}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\BookingAngel\}[$RV_CIDNUMBER]{}[intro Message]{2}
220546.25 3 tts generate start[This is a transferred call. Caller I.D Press 1 to accept the call or any other number to reject it ]
220546.25 3 tts generate wait
220546.38 3 tts generate finish
220546.38 3 state [Transfer Dean] Playing (C:\Program Files\VoiceGuide\data\tts3.wav)
220546.38 3 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts3.wav
220546.38 3 timer clear
220546.42 3 tw wav->vox convert end 816093,C:\Program Files\VoiceGuide\data\tts3.vox,1,0,,
220546.44 3 play start ok, lPlayId=816140
220551.59 3 tw dtmf 8 (3,56,56)
220551.59 3 event 8, code=56, state=1904
220551.59 3 LsXfer_4_PlayAnn : 56(8),8,0,0,0,,,
220551.59 3 rv add [Transfer Dean]{8}
220551.61 3 timer set 0.5 EV_PLAY_FINISHED
220551.61 3 play PlaySoundStop ok
220551.61 3 tw DialogicEvent 134,TDX_CST,56,0,0,DE_DIGITS,,
220551.61 3 event TDX_CST, code=134, state=1904
220551.61 3 LsXfer_4_PlayAnn : 134(EV_UNKNOWN_134),TDX_CST,56,0,0,DE_DIGITS,,
220551.61 3 path {TDX_CST} not found
220551.61 3 tw PlayEnd 3 816140
220551.61 3 play end id=816140, (current ID)
220551.61 3 event EV_PLAY_FINISHED, code=8001, state=1904
220551.63 3 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
220551.63 3 path {EV_PLAY_FINISHED} not found
220551.63 3 xfer dial !1
220551.63 3 tw DialogicEvent 129,TDX_PLAY,816140,0,0,,,
220551.63 3 event TDX_PLAY, code=129, state=1906
220551.63 3 LsXfer_5B : 129(EV_UNKNOWN_129),TDX_PLAY,816140,0,0,,,
220551.84 3 tw PlayEnd 3 0
220551.84 3 play end id=0, (old ID) current id=816140
220551.84 3 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
220551.84 3 event TDX_DIAL, code=132, state=1906
220551.84 3 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,,
220551.84 3 sXferDialResult_SuccOrFail=XferToBeAborted
220551.84 3 path {rejected} not found
220551.84 3 going down False path (iXferType=23) state:LsXferCallRejected
220551.84 3 timer clear
220551.84 3 state [No Connection] Playing
220551.84 3 tts generate start[We are experiencing larger than expected call volumes. Please leave a message after the beep including your name and contact telephone number and one of the booking angel team will contact you shortly.]
220551.84 3 tts generate wait
220552.00 3 tts generate finish
220552.00 3 state [No Connection] Playing (C:\Program Files\VoiceGuide\data\tts3.wav)
220552.00 3 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts3.wav
220552.00 3 timer clear
220552.05 3 tw wav->vox convert end 821718,C:\Program Files\VoiceGuide\data\tts3.vox,1,0,,
220552.05 3 play start ok, lPlayId=821765
220604.33 3 tw PlayEnd 3 821765
220604.33 3 play end id=821765, (current ID)
220604.33 3 event EV_PLAY_FINISHED, code=8001, state=1100
220604.33 3 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
220604.33 3 path {EV_PLAY_FINISHED} not found
220604.33 3 timer set 10 EV_TIMEOUT_HANGUP
220604.34 3 timer set 0 EV_TIMEOUT_GOTOMODULE
220604.34 3 event EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
220604.34 3 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
220604.34 3 path {EV_TIMEOUT_GOTOMODULE} not found
220604.34 3 tw DialogicEvent 129,TDX_PLAY,821765,0,0,,,
220604.34 3 event TDX_PLAY, code=129, state=6001
220604.34 3 timer clear
220604.34 3 state [Message] Recording
220604.34 3 rv replace start: [\Feedback\$RV_CIDNUMBER_$RV_STARTTIME]
220604.34 3 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{12/10/2005 10:05:14 PM}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\BookingAngel\}[$RV_CIDNUMBER]{}[intro Message]{2}[Transfer Dean]{8}
220604.34 3 rv replace end: [\Feedback\_12/10/2005 10:05:14 PM]
220604.34 3 rv add [Message]{\Feedback\_12/10/2005 10:05:14 PM}
220604.34 3 RecSoundStart [\Feedback\_12/10/2005 10:05:14 PM] call
220604.34 3 state [Message] Recording \Feedback\_12/10/2005 10:05:14 PM
220604.36 3 RecSoundStart err[dlgc dx_fileopen(strFname=\Feedback\_12/10/2005 10:05:1.vox) => -1, [dx_fileerrno=2, ENOENT, No such file or directory; invalid device name; file or path not found.]]
220604.36 3 rv add [Hangup Time]{12/10/2005 10:06:04 PM}
220604.36 3 state Hanging up call...
220604.36 3 HangupCall_Common hCall=3
220604.36 3 rec RecSoundStop ok
220604.38 3 play PlaySoundStop ok
220604.38 3 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
220604.38 3 fnHangupCall end
220604.38 3 timer set 90 EV_TIMEOUT_GOTOMODULE
220604.38 2 event EV_REC_FINISHED, code=8003, state=0
220604.41 3 event callstate IDLE 3 0 0
220604.42 3 WorkingMode@Idle=
220604.42 3 timer clear
220604.42 3 rec RecSoundStop ok
220604.42 3 play PlaySoundStop ok
220604.42 3 rv add [CallEndTime]{12/10/2005 10:06:04 PM}
220604.42 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
220604.42 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
220604.42 3 event TDX_SETHOOK, code=135, state=900
220604.42 3 LsAwaitingCalls EV_UNKNOWN_135
220605.20 3 event callstate OFFERING 3 0 0
220605.20 3 script interpretor: VgMulti v6.0.1049
220605.20 3 init LineState ResetAtStartOfNewCall.
220605.20 3 dont answer yet, wait for CallerID information.
220605.20 3 tw ring 1
220605.22 3 ring time since last ring (ms): 0
220605.22 3 rv clear all
220605.22 3 init LineState ResetAtStartOfNewCall.
220605.22 3 answer the call
220605.22 3 timer clear
220605.22 3 timer clear ignored - waiting for line re-init to occur first
220605.22 3 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
220605.22 3 event TDX_CST, code=134, state=6001
220605.48 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
220605.48 3 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=6001
220605.48 3 init atidle reinit : start
220605.48 3 init atidle reinit iConferenceOtherLegLid=-1
220605.48 3 init atidle reinit : reset all LineState variables
220605.48 3 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
220605.48 3 state Waiting for a call...
220605.81 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
220605.81 3 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=6001
220605.95 3 event callstate CONNECTED 3 0 0
220605.95 3 WorkingModes tapi= script=
220605.95 3 Inband detection not enabled
220605.95 3 StartLoadedVgs at 12/10/2005 10:06:05 PM
220605.95 3 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState
220605.95 3 set sScriptToRunOnHangup=[] in StartLoadedVgs
220605.95 3 rv add [$RV_STARTTIME]{12/10/2005 10:06:05 PM}
220605.95 3 rv add [$RV_DEVICEID]{3}
220605.95 3 rv add [$RV_CIDNAME]{}
220605.95 3 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
220605.97 3 rvns add [scriptsPath]{C:\BookingAngel\}
220605.97 3 rv add [$RV_CIDNUMBER]{}
220605.97 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
220605.97 3 event TDX_SETHOOK, code=135, state=6001
220605.97 3 tw DialogicEvent 134,TDX_CST,153,0,0,DE_LCON,,
220605.97 3 event TDX_CST, code=134, state=6001
220605.97 3 timer clear
220605.97 3 state [intro Message] Playing
220605.97 3 tts generate start[Hi, You have reached the offices of booking angel. To hear a demonstration of the booking angel service press 1, for sales press 2, If you are a restaurant ringing about a booking or cancellation press 3, For all other inquiries press 4]
220605.97 3 tts generate wait
220606.19 3 tts generate finish
220606.19 3 tts play abort as no call on line
220608.95 3 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1,
220608.95 3 event RINGBACK, code=134, state=1100
220608.95 3 LsPlayMsg EV_UNKNOWN_134,RINGBACK
220608.95 3 path {RINGBACK} not found
220608.95 3 event TID_RNGBK1, code=134, state=1100
220608.95 3 LsPlayMsg EV_UNKNOWN_134,TID_RNGBK1
220608.95 3 path {TID_RNGBK1} not found
220608.95 3 event TDX_CST, code=134, state=1100
220608.95 3 LsPlayMsg EV_UNKNOWN_134,TDX_CST
220608.95 3 path {TDX_CST} not found
220610.44 3 tw DialogicEvent 134,TDX_CST,202,0,0,DE_TONEON,DISCONNECT_Telstra,
220610.44 3 event DISCONNECT_Telstra, code=134, state=1100
220610.44 3 LsPlayMsg EV_UNKNOWN_134,DISCONNECT_Telstra
220610.44 3 path {DISCONNECT_Telstra} not found
220610.44 3 rv add [Hangup Time]{12/10/2005 10:06:10 PM}
220610.44 3 state Hanging up call...
220610.45 3 HangupCall_Common hCall=0
220610.45 3 rec RecSoundStop ok
220610.45 3 play PlaySoundStop ok
220610.45 3 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
220610.45 3 HangupCall : lCallHandle& = 0 - lets close and open line
220610.45 3 state Waiting for a call...
220610.45 3 fnHangupCall end
220610.45 3 event TDX_CST, code=134, state=900
220610.45 3 LsAwaitingCalls EV_UNKNOWN_134
220610.50 3 event callstate IDLE 3 0 0
220610.50 3 WorkingMode@Idle=
220610.50 3 timer clear
220610.50 3 LineState(iLineId).iVgsIdx = 0
220610.50 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
220610.50 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
220610.50 3 event TDX_SETHOOK, code=135, state=900
220610.50 3 LsAwaitingCalls EV_UNKNOWN_135
220611.50 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
220611.50 3 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
220611.50 3 init atidle reinit : start
220611.50 3 init atidle reinit iConferenceOtherLegLid=-1
220611.50 3 init atidle reinit : reset all LineState variables
220611.50 3 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
220611.50 3 state Waiting for a call...
220611.58 3 event callstate OFFERING 3 0 0
220611.58 3 script interpretor: VgMulti v6.0.1049
220611.58 3 init LineState ResetAtStartOfNewCall.
220611.58 3 dont answer yet, wait for CallerID information.
220611.58 3 tw ring 1
220611.58 3 ring time since last ring (ms): 0
220611.58 3 rv clear all
220611.58 3 answer the call
220611.58 3 timer clear
220611.59 3 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
220611.59 3 event TDX_CST, code=134, state=6001
220612.13 3 event callstate CONNECTED 3 0 0
220612.14 3 WorkingModes tapi= script=
220612.14 3 Inband detection not enabled
220612.14 3 StartLoadedVgs at 12/10/2005 10:06:12 PM
220612.14 3 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState
220612.14 3 set sScriptToRunOnHangup=[] in StartLoadedVgs
220612.14 3 rv add [$RV_STARTTIME]{12/10/2005 10:06:12 PM}
220612.14 3 rv add [$RV_DEVICEID]{3}
220612.14 3 rv add [$RV_CIDNAME]{}
220612.14 3 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
220612.14 3 rvns add [scriptsPath]{C:\BookingAngel\}
220612.14 3 rv add [$RV_CIDNUMBER]{}
220612.14 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
220612.14 3 event TDX_SETHOOK, code=135, state=6001
220612.16 3 timer clear
220612.16 3 state [intro Message] Playing
220612.16 3 tts generate start[Hi, You have reached the offices of booking angel. To hear a demonstration of the booking angel service press 1, for sales press 2, If you are a restaurant ringing about a booking or cancellation press 3, For all other inquiries press 4]
220612.16 3 tts generate wait
220612.34 3 tts generate finish
220612.34 3 state [intro Message] Playing (C:\Program Files\VoiceGuide\data\tts3.wav)
220612.34 3 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts3.wav
220612.34 3 timer clear
220612.39 3 tw wav->vox convert end 842062,C:\Program Files\VoiceGuide\data\tts3.vox,1,0,,
220612.41 3 play start ok, lPlayId=842109
220616.45 3 tw DialogicEvent 134,TDX_CST,202,0,0,DE_TONEON,DISCONNECT_Telstra,
220616.45 3 event DISCONNECT_Telstra, code=134, state=1100
220616.45 3 LsPlayMsg EV_UNKNOWN_134,DISCONNECT_Telstra
220616.45 3 path {DISCONNECT_Telstra} not found
220616.45 3 rv add [Hangup Time]{12/10/2005 10:06:16 PM}
220616.45 3 state Hanging up call...
220616.45 3 HangupCall_Common hCall=3
220616.47 3 rec RecSoundStop ok
220616.48 3 play PlaySoundStop ok
220616.48 3 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
220616.48 3 fnHangupCall end
220616.48 3 event TDX_CST, code=134, state=900
220616.48 3 LsAwaitingCalls EV_UNKNOWN_134
220616.48 3 tw PlayEnd 3 842109
220616.48 3 play end id=842109, (current ID)
220616.48 3 event EV_PLAY_FINISHED, code=8001, state=900
220616.48 3 LsAwaitingCalls EV_PLAY_FINISHED
220616.48 3 tw DialogicEvent 129,TDX_PLAY,842109,0,0,,,
220616.48 3 event TDX_PLAY, code=129, state=900
220616.48 3 LsAwaitingCalls EV_UNKNOWN_129
220616.52 3 event callstate IDLE 3 0 0
220616.53 3 WorkingMode@Idle=
220616.53 3 timer clear
220616.53 3 rec RecSoundStop ok
220616.53 3 play PlaySoundStop ok
220616.53 3 rv add [CallEndTime]{12/10/2005 10:06:16 PM}
220616.53 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
220616.53 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
220616.53 3 event TDX_SETHOOK, code=135, state=900
220616.53 3 LsAwaitingCalls EV_UNKNOWN_135
220617.52 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
220617.52 3 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
220617.52 3 init atidle reinit : start
220617.52 3 init atidle reinit iConferenceOtherLegLid=-1
220617.52 3 init atidle reinit : reset all LineState variables
220617.52 3 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
220617.52 3 state Waiting for a call...
220617.84 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
220617.84 3 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
Trace shows that after dialing the destination number and starting the play the announce message:
The Dialogic card advised VG that DTMF 8 was pressed
so the call was dropped and VG went back to original call:
Also, CallerID was never provided on this call:
It should have gone to the fail path in the script then....
There is a problem when it comes to reconnecting back the calls whether it is !1 to go back to the original call (and play the fail path)
or !3 to connect the calls in 3 way chat.
Can you suggest a solution
Trace shows that system did go down fail path afterwards:
!1 should have resulted in original incoming call being connected to and that caller should have heard the [No Connection] module playing.
If call was accepted (DTMF 1 was pressed) then !3 would have been issued...
