VG And MySql - ODBC not working on restart
Hello!
I have noticed that sometimes when I reboot my computer and call one of my scripts, I get the message; ERROR connecting to the database. I am for sure that no change has been made in the script itself, neither in the MySQL driver.
How do I solve this situation? Well, if I close VG and inmediately I start it again then it works BUT I wonder if there is something to avoid this situation; for example wait x minutes before starting VG after rebooting the system.
Please help!
jose
Maybe the MySQL service takes a bit longer to start? If that's the case then delaying the start of VG until after the MySQL database starts would be the right approach.
After the last mail I´ve seen that this may happen even if I didn´t restart the computer, but again if I close VG and then I start it again then it works fine.
Any ideas?
Jose
A "Database Query" module makes a new connection to the database every time it's visited, and after it's finished the DB connection is closed, so the timing of when the VoiceGuide app itself is started doe not really matter.
Are you saying that you are seeing that all of a sudden the database connection does not work work?
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=0
SapiWrapOcx=0
Then restart VG/system and make a test call which demonstrates the problem, and then do the VG restart and make a call which results in a successfull DB Query.
Hello again!
Now I know that when I start Voiceguide with the script attached with this post then for some reason I always get this message:
"ERROR 6.0.3095 OpenDatabase [3146:ODBC: anrop misslyckades.]"
but if I start voiceguide by pressing the VoiceGuide icon then it works. I´ve checked the properties and when pressing this icon it will start the program C:\Program\VoiceGuide\VgMulti.exe just like in my script (see attached file)? I need this script in my computer in order to start this and other applications after a power failed.
What am I missing?
Thank you for your help!
jose
1024vgm.zip
Does the ODBC driver log indicate anything?
Maybe the way you start the VgMulti.exe has something to do with it. I see that "Win32_ScheduledJob" object is used to start VG. Try just doing a simple Shell to start VgMulti.exe (with some delay beforehand to let the Dialogic service and Databases etc. to start before starting VG)
Where can I see that log?
I have this problem even without rebooting the computer. The first time I discovered this problem was after rebooting the computer. But now I am sure that those services you mentioned aboved are running when I execute my script and for some reason I can´t connect to the database. So I have to close the voiceguide application and start it again by pressing the voiceguide icon instead.
What can I do?
\Jose
Most ODBC drivers have some logging - you should check the ODBC driver documentation.
Sounds like using "Win32_ScheduledJob" object is used to start VG causes some problems with the ODBC drivere.. Try just doing a simple Shell call to start VgMulti.exe.
I don´t really understand what you mean by simple Shell call? Do you mean a batch file?
I´d appreciate if you can point me in the right direction!
\Jose
Here are as few code snippets which may point in the right direction:
Snippet 1:
Set sh = CreateObject("WScript.Shell")
Set wsx = sh.Exec("VgMulti.exe")
Snippet 2:
Set objShell = CreateObject("Wscript.Shell")
objShell.Run "VgMulti.exe"
Snippet 3:
Const NORMAL_WINDOW = 1
Set objShell = CreateObject("Shell.Application")
objShell.ShellExecute "VgMulti.exe", "", , , NORMAL_WINDOW
Thank you about that. It works fine now.
Sounds like using "Win32_ScheduledJob" object is used to start VG causes some problems with the OPDBC drivere
The problem with the task scheduler is that it starts voiceguide with the "SYSTEM" as the user account instead of my own account.
Thank you again!
\Jose
