Simple Question - Evaluate Expression Module
I want to make the input keyed by a user change the value of a result variable used later in the script.
For example if the user keys 1 the result variable should take a value of 002
and if the user key 7 the result variable should take a value of 014
all other keyed values are invalid (and this is coped with)
I also want to define a default value for teh result variable if the user does not take the path where they are invited to make teh keyed entry.
I guess I need to use evaluate expression module but any guidance would be appreciated
I want to use a keyed value to set the value of a result variable used later in the script.
Specifically if the user keys 1 I would like to set the RV to 002 (must be three digits)
and if the user keys 7 set the RV to 014
No other choices are necessary.
If the branch has not been taken where the user makes this keyed input I would like to set a default value to the RV of 000 (presumably earlier in the script)
I assume I can use the evaluate expression module to to do this but any guidance would be appreciated.
Thanks in advance
BTW Apologies if I have not double posted
Yes, the evaluate expression module can be used to assign values to RVs.
Here is a sample script the demonstrates the approach:
rvset.vgs
