Prompt Message Loop (when Using A Voice Modem)
Hello.
The prompt message loop plays 10 times before the sytem hangs up. How can I change this setting? Is it possible to do if on a OutDial_New.xml file?
Thanks.
The OutDial_New.xml file has an "Answer Timeout" setting. You can try using that setting to see if it affects anything.
For better control of outgoing calls you should look at getting a Dialogic card and using "VG for Dialogic".
I've tried that and it didn't work. The software still plays the message 10 times. It seems that VG doesn't follow this setting... Btw, the minimum timeout I could successfully enter was 10 (checking on the database entry). If I use "9" or "09" or less, the database is still filled with "10".
Any other suggestion? (besides the one of using the dialogic board, which we will do in a near future)
Thanks.
Looks like you can change the number of times the announce message is played using the AnnReplay entry in the [VGDialer] section of the VG.INI file.
eg. Adding this line to the [VGDialer] section:
AnnReplay=5
should result in the announcement only being played 5 times.
