Hangup Source
Where can we find more information about hangup source statuses using DIALOGIC JCT cards?
The debug messages that are reported in internal debug traces are not formally documented.
Primary use of these messages (as with all of debugging/trace files) is for internal debugging/tracking of what precisely happened on the call. They are comprised of unique descriptive tags to assist in quick identification of what situation lead to call being ended.
The text of these tags can also change between releases.
Each module type has a number of possible causes/triggers that would result in call being ended.
Most of these are related to timeout awaiting user input or disconnect tone detections etc.
