Not Copying Sql Statement When Copying Script
Sounds like you are trying to open the script using an older version of Script Designer then what the script was saved with.
The script opens fine and all the SQL statements can be seen in this version of script editor: 6.0.3101 (Go to Help->About menu to see version)
If you have multiple VoiceGuide system installations then please ensure each site is running the same version if you are moving scripts between various systems.
