Termination On Global End-Of-Call Dtmf (D)
We found something like this:
145957.889 22 7 3 ev dtmf d (42205544,100,0) ConfOtherLeg=101
145957.889 22 7 3 q_scr + evScriptEvent 100 d
145957.889 22 101 34 q_scr + evScriptEvent 100 OTHER_LEG_d
145957.889 7 7 3 q_scr run evScriptEvent sCode=[d] iActionID=0, crn=0 [0|0|0|0|0][|||||] 00:00:00 max:4|00:00:00.1800103
145957.889 7 7 3 se d 100 0|0|0 || LineState=LS_PLAY_PLAYMSGFINISHED
145957.889 7 7 3 HangupCall (Global End-of-Call DTMF (d)) crn_in=0, L1=Connected, L2=Running_Normal, lPlayId=0, lRecId=0
145957.889 7 7 3 ccrn_connected=2840168, crn_NewCallArriving=0, crn_CurrentMakeCall=0, crn_InProcessOfReleasing=0
145957.889 7 7 3 hangup the 2nd leg of call - LineId=101, port=3
145957.890 7 7 3 TsReset [HangupCall], OtherLegLid=101
145957.890 7 q_tel + cmd_TsReset 0 [0,0,0,0,0][dtiB1T3||dtiB2T4||]
145957.890 7 7 3 OtherLegLid_ClearBoth 7 101 caller:HangupCall
145957.890 7 101 34 OtherLegLid_ClearBoth 7 101 caller:HangupCall
145957.890 8 q_tel run cmd_TsReset 0 00:00:00 max:5|00:00:00.2980171
145957.890 7 101 34 q_scr + evScriptEvent 0 OTHER_LEG_END_OF_CONFERENCE_HANGUPCALL
145957.890 7 7 3 rv add Hangup Source|Global End-of-Call DTMF (d)
Can You explain what is Global End-of-Call DTMF (d) as hangup source?
How to make VG not sensible on something like this?
The DTMF "D" tone is used by some PBXs to indicate end of call.
To stop VoiceGuide reacting to this tone please do this:
In VG.INI file in section [PBX] please remove or comment out the HangupOnDtmf setting.
