Low Cost Card
#1 researcher 02 December 2017 - 08:52 PM
Dear Sir
I am having Window XP SP3 with CPU i3 2GHz, RAM 2GB . I want to develop an  IVRS with auto dialing as the only basic feature. Where can I get the lowest cost card online? Please advice the card. Easy installation will be appreciated. I am not expert.
prof. Bhagat
#2 SupportTeam 03 December 2017 - 04:45 AM
Used Dialogic cards can be sourced on EBay. Searching EBay for the Dialogic card models: D/4PCIUF and D/41JCT should let you find some.
Card installation is pretty straightforward. Just place in system and then install the Dialogic card drivers available from our Downloads page.
#3 researcher 04 December 2017 - 03:38 PM
Thanka
#4 researcher 04 December 2017 - 03:50 PM
I found this search. Which lowest cost card will be ok to go for https://www.ebay.com...=p2054436.m1684
#5 SupportTeam 04 December 2017 - 04:06 PM
Do a search for this:
Dialogic D/4PCIU
the D/4PCIU can be used in both traditional 5V PCI slots, and in the 3.3V PCI slots.
Here is one of the search results:
https://www.ebay.com...XQAAOSwT2daGLuE
#6 researcher 04 December 2017 - 07:43 PM
Can I use this ?
or this ?
https://www.ebay.com...5.c100009.m1982
#7 SupportTeam 04 December 2017 - 10:00 PM
Both are fine.
The second card (D/41JCT) has more functionality then the first card (D/4PCIUFW). Main difference is that you can bridge two calls together on the D/41JCT card.
D/41JCT is a 'full length' card, and the D/4PCIUF is a 'half length' card.
In addition: Please note that the D/41JCT listing shows a PCI (universal) card, but description says PCIe (ie. 'PCI Express'). You should check with seller what type of card it is.
Edited by SupportTeam, 05 December 2017 - 08:51 AM.
Added note about PCIe
#8 researcher 05 December 2017 - 01:54 AM
Thanks support team. This helps me fully.
#9 researcher 05 December 2017 - 08:36 PM
Before you close this thread just let me know if each of the following will work for voice and fax?
https://www.ebay.com...awAAOSwPYZU3HOU
https://www.ebay.com...r4AAMXQC-tTFhWB
https://www.ebay.com...E0AAOSw0JpV5gS5
https://www.ebay.com...CUAAOxyVaBSwTPe
I will buy the best from the above upon your recommendation.
#10 SupportTeam 05 December 2017 - 09:07 PM
Number 3 and 4 :
Dialogic D4PCIUFWEU Voice Board
and
Dialogic D/41JCT-LS
are both equally good for fax and voice
Do not buy 1 or 2.
#11 researcher 05 December 2017 - 09:27 PM
:) Thanks
#12 researcher 05 December 2017 - 09:42 PM
How about this one? Does it work for voice and fax if not  better than 3, 4 above?
https://www.ebay.com...ZgAAOSwbopZUQMP
#13 SupportTeam 05 December 2017 - 09:58 PM
That card (Dialogic D120JCTLSW) is a 12-port Analog card. (D/41JCT and D/4PCIU series cards are all 4 port cards).
It's also a PCIe card, not PCI.
It's good value at that price.
#14 researcher 06 December 2017 - 10:40 PM
I am interested in buying this one
Is it ok if I place order now? Just want voice and fax for developing an ACD and voice attendant.
#15 researcher 07 December 2017 - 12:30 AM
Will the following cards be useful for ACD & voice attendant works?
https://www.ebay.com...I8AAOSwUdlWcuUP
https://www.ebay.com...yMAAOSwXYtYwBWn
#16 SupportTeam 07 December 2017 - 06:45 AM
For ACD systems you must use 'JCT' series cards. The last 3 links posted are not JCT cards.
Analog JCT cards are: D/41JCT and D/120JCT.
#17 researcher 08 December 2017 - 01:28 AM
If I just want to create a script  for outbound dialing services then can I use this card?
https://www.ebay.com...2IAAOxy63FS2U~A
#18 SupportTeam 08 December 2017 - 06:44 AM
No. That is a really old card. Also, it is a ISA card.
Both cards posted by you in this post: http://voiceguide.co...c=12748&p=43034
and cards 3 and 4 in your post here: http://voiceguide.co...c=12748&p=43048
were fine. Why didn't you select one of those 4 cards?
#19 researcher 08 December 2017 - 04:31 PM
Purchase order placed for
Dialogic D4PCIUFWEU Voice Board - PCI - 4 x Phone Line (RJ-11) - Plug-in Card
Also tagged with one or more of these keywords: dialogic, refurbished
