Voice Mail Problem
I am having an issue where some of the users are trying to access messages and are getting a recording saying" The sound file specified could not be found".
I can see that the messages are in the specific vmail boxes when I run the Vmail manager.
These seem to be calls where people have hung up and are only 5 or so seconds in length.
In the Voicemail Manager what is the 'Minimum Recording Time Lenth' set to?
I am using Version 4.8.45 Professional.
The minimum is set to 1, max set to 45.
Once they are accessing the messages they sometimes get that "The sound file specified could not be found"
4403.txt
OK, I see the problem - we should have a fix available for this in a couple of days.
