Calls Hanging Up
I am having an issue where one of the 4 extentions I am using to access Voice Guide is getting the calls dropped. It doesn't start the vmail main greeting , it simply dials in, voice guide picks up the call then hangs up.
I have attached a trace as well.
I am using the 4.8.45 version.
hangup.txt
Looks like there is something wrong with the wave driver assignments on that line, we can see the error in the trace:
waveOutOpen MMSYSERR_ALLOCATED but hWaveOut = NULL
Can you try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony device first.
Has this line always had this problem or did it start having it all of a sudden? Did you install any sound related software or any other wave drivers around the time when this started happening?
It started to happen all of a sudden. To my knowledge there hasn't been any other installs done on the machine.
I will try to remove and re-install.
