Using Wscript.sleep In "run Vbscript" Module
Maybe running some process that times out after a certain number of seconds? Like a ping to a non-extiant address?
Please note that setting in VG.INI:
[moduleRunScript]
Engine=WScript
should switch system back to using the old WScript way of running the VBS scripts, which will allow you to use the Wscript objects in the VBScripts again.
If you have problems when Engine=WScript is set then please post trace capturing that call
