Id Number Vs. Port Number
#1 meir 30 September 2013 - 06:11 PM
Hello,
Even after reading the help file, I still don't fully understand the difference between ID Number and Port Number.
$RV_LINEID
Identification number of the line device which is handling this call. Can be used in Run Program module to help the called program generate the appropriate Results filename, or in the COM interface to return results to the correct line. The ID number refers to an internal line ID number - not the position in which that line's status is displayed in VoiceGuide's status window.
$RV_PORTNUMBER
Line Device's position is VoiceGuide's line status listing. Numbering starts from the top, with first line/port having a $RV_PORTNUMBER of 1, the seconds line/port having a $RV_PORTNUMBER of 2, etc.
I have this Dialogic Card - D4PCIUFEQEU
How many Line_IDs and Ports do I have?
Each Line_ID contain couple of Ports or is it vice versa?
I would like to extract data from the system log files, and need to distinguish between each call (phone line)
Thank you
Meir Levin
#2 SupportTeam 01 October 2013 - 09:14 AM
Port is a physical line/channel number used to carry the call. Port count starts at 1 and increments by 1 for each next port.
LineID is a reference number for devices used by ports. It can be any unique number.
D/4PCI* series cards have 4 ports.
D/4PCI* cards only have 1 'LineID' per port.
Each port can have multiple LineIDs associated with it.
#3 Hoa Bui 08 July 2015 - 02:24 PM
How do you config multiple Line for one port?
#4 SupportTeam 08 July 2015 - 03:15 PM
It's not something that is configured. IDs are just reference numbers for the various types of 'devices' that are used by each port.
eg. each port can have a 'line' device, a 'voice' device, a 'fax' device, a 'speech' device, all attached to and be used by one port.
