Objvbsorexeprocess.kill : Process Has Exited
#1 Sebastian 30 April 2015 - 10:03 PM
In one of the log files I found this error:
095837.744   7  22   8 ERROR v7.4.5546.36085 (09-Mar-15 20:02:50.85) LsRunWaitTillFinished (timeout) objVbsOrExeProcess.Kill : Process has exited, so the requested information is not available.
   at System.Diagnostics.Process.EnsureState(State state)
   at System.Diagnostics.Process.get_ProcessName()
   at System.Diagnostics.Process.ToString()
   at System.String.Concat(Object arg0, Object arg1, Object arg2)
   at vgEngine.ScriptRunsStateMachine.(Int32 iLineId, Int32 iCode, String sCode, Int32 iParam1, Int32 iParam2, Int32 iParam3, String sParam1, String sParam2, String sParam3)
Does this have to do with this issue? Maybe this is the reason? I send log files.
#2 SupportTeam 30 April 2015 - 11:04 PM
It just indicates that a VBScript process has completed just before the time when system timed out awaiting its completion.
This should probably not be reported as an error.
Best way to avoid such issues is to have the VBScript return the result to VoiceGuide using Run_ResultReturn, or to set the timeout to a value significantly higher then what that VBScript usually takes to run.
This would not be the cause of memory issues on your system that looks like you are having ( http://www.voiceguid...showtopic=11919 )
