Calltrack Table
#1 mityay 09 May 2015 - 04:25 AM
I was advised to write here instead of email. Here is the problem.  I insert call information into three tables, callque, calltrack, portstouse. The call is made, but the calltrack is not updated.  Please help.
#2 SupportTeam 11 May 2015 - 02:46 PM
it looks like you are inserting the data into the voiceguide database directly, and are not using the Outgoing Call Loader or Data Files etc.
vgEngine shows that system is using the default SQLite database, which on this system is located at: C:\VoiceGuide\data\vgDb.db
Can you please post the vgDb.db file that has the inserted calltrack entry in it?
vgEngine trace shows that SQL commands to update calltrack were ran:
134957.307  12               db    PerformWork_RunCoreSql ExecuteNonQuery call: UPDATE calltrack SET History='dialed@134957, ', TimeLastCall='2015-05-07 13:49:57', RetriesLeft=2 WHERE (QueID=1 OR QueGUID='1fa19d98-7c6f-44dc-b501-3b189d238996');
134957.308  12               db    PerformWork_RunCoreSql cmd_CoreSql.ExecuteNonQuery returned
135028.324  12               db    PerformWork_RunCoreSql ExecuteNonQuery call: UPDATE calltrack SET Outcome='Answered_Machine', History='dialed@134957, Answered_Machine@135028, Answered_Machine@135028, ', TimeCallAnswered='2015-05-07 13:50:28', RetriesLeft=2 WHERE (QueID=1 OR QueGUID='1fa19d98-7c6f-44dc-b501-3b189d238996');
135028.325  12               db    PerformWork_RunCoreSql cmd_CoreSql.ExecuteNonQuery returned
so most likely no entry in calltrack table satisfied this:
This can be further confirmed by looking at the vgDb.db or the SQL that is used to insert entry into calltrack table.
Please .ZIP up the vgDb.db before posting.
BTW.
Many problems that occur when inserting data directly into database can be resolved by comparing inserts with how the Outgoing Call Loader loads the data into the database.
An application to view SQLite database files' contents can be found here: http://sqlitebrowser.org/
#3 mityay 12 May 2015 - 04:46 AM
Sorry, I don't have the same vgDb anymore, but I created a new test case.  Please see the attached traces showing the problem.
Guid of the new test call is '4f78c548-bd4d-4f60-a9bb-77d3fd25c189'.
I looked at how Telephone Number Loader inserts row, and I do it the same way, but can't make this work.
Thank you.
#4 SupportTeam 13 May 2015 - 12:22 PM
Please update your system to this version of VoiceGuide:
[old link removed]
This version changes how updates to calltrack table are made.
Please let us know if you still encounter issues after the update.
1. Stop VoiceGuide service and exit all VoiceGuide programs. (eg Script Designer, Voicemail Manager, etc) and all other programs.
3. Start VoiceGuide service.
Running a VoiceGuide install over the top of an existing install will NOT overwrite existing configuration or license files (Config.xml, ConfigLine.xml, VG.INI, VmBoxList.xml, userinfo.lic) and will not remove any of users script or sound files, and will not remove any log files etc.
Please note however that the local SQLite outdial database will be re-initialized. If you are using the local SQLite outdial database and have any queued outgoing calls that you would like to keep then this database should be backed up first.
#5 mityay 14 May 2015 - 08:43 AM
This solved the problem. The calltrack table is updated by VG now. Thank you.
