Voiceguide Tts Error
#1 minh 12 August 2015 - 03:28 AM
Im trying to convert our old VoiceGuide version 5 to VoiceGuide version 7.
VoiceGuide version 5 is on a Windows 2000 box.
VoiceGuide version 7 is on Windows 7 64 bit enterprise.
104750.268  4020        ------------------------------------------------------------------------------
104750.268  4020        ktTtsSapi v7.5.0
104750.268  4020        Jun  2 2015 13:20:29
104750.268  4020        zsLogPath [C:\Program Files (x86)\VoiceGuide\log\] log_level=10
104750.268  4020        options   []
104750.268  4020        SpEnumTokens call
104750.268  4020        GetCount call
104750.268  4020        GetCount returned ulNumTokens=1
104750.268  4020        tts voice 0 : Microsoft Anna - English (United States)
104750.268  4020                      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\MS-Anna-1033-20-DSK
104750.268  4020  WARN  pToken_EngineUsed == NULL, no default TTS engine set!
104750.268  4020        Create tts thread. threadnumber= 1, handle= 2144 threadid= 3752
104750.268  3752          1   ProcessTTSJob thread created
104750.284  4020        ThreadPriority -1
#2 SupportTeam 12 August 2015 - 12:26 PM
That trace shows that the TTS engine to use was not set in VG.INI
Please see instruction here on how to configure VoiceGuide to use a specific TTS engine:
http://www.voiceguid.../config_tts.htm
Please try using this for the TTSEngine entry in the [SAPI] section of VG.INI :
TTSEngine=Microsoft Anna - English (United States)
#3 minh 13 August 2015 - 06:30 AM
Thank you. I also dont see this in the vg.ini file
[SAPI]
SpStreamFormat=xxxxx
when the system speaks it comes out all mumble and is really hard to hear. I tired changing the TTSEngine to Microsoft Mary but still the same thing happens.
#4 minh 13 August 2015 - 07:06 AM
This is the updated from the log. Also ran the TTSAPPS and every sounded clear. Voiceguide can play wave files just fine when I phone in. Its just tts that sounds mumbled.
151900.958  3264        ktTtsSapi v7.5.0
151900.958  3264        Jun  2 2015 13:20:29
151900.958  3264        zsLogPath [C:\Program Files (x86)\VoiceGuide\log\] log_level=10
151900.958  3264        options   []
151900.958  3264        ------------------------------------------------------------------------------
151900.958  3264        SpEnumTokens call
151900.958  3264        GetCount call
151900.958  3264        GetCount returned ulNumTokens=4
151900.958  3264        tts voice 0 : Microsoft Anna - English (United States)
151900.958  3264                      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\MS-Anna-1033-20-DSK
151900.958  3264        tts voice 1 : Microsoft Mary
151900.958  3264                      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\MSMary
151900.958  3264        default tts voice set to [Microsoft Mary] => 0
151900.958  3264        tts voice 2 : Microsoft Mike
151900.958  3264                      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\MSMike
151900.958  3264        tts voice 3 : Sample TTS Voice
151900.958  3264                      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\SampleTTSVoice
151900.958  3264        Create tts thread. threadnumber= 1, handle= 2104 threadid= 3688
151900.958  3264        ThreadPriority -1
151900.973  3688          1   ProcessTTSJob thread created
#5 SupportTeam 13 August 2015 - 07:20 AM
Could you please post the other traces from VoiceGuide v7 \log\ subdirectory.
(just today's traces and please .ZIP them up and attach the .ZIP file to the post)
Also please attach the TTS generated .WAV files - they can be found in VoiceGuide's \temp\ subdirectory.
#6 minh 13 August 2015 - 11:38 PM
Please see attached. I made a voice recording aswell. the temp folder is empty.
  • Attached File  log.zip   799.4KB   63 downloads
#7 minh 13 August 2015 - 11:47 PM
please see attach file, I enabled savetofile
  • Attached File  temp.zip   815.28KB   58 downloads
#8 SupportTeam 14 August 2015 - 07:31 AM
Attached trace captures two incoming calls, but neither of the two calls used TTS at any stage.
The script is using a 'Say Number' module to speak out some numbers, and the recording of the call shows that this is what you must be referring to, as it is the numbers played out by the 'Say Number' module that do not play correctly.
'Say Number' type modules do not use TTS.
'Say Number' type modules play back numbers/dates/etc by concatenating a series of pre-recorded sound files. These sound files are in VoiceGuide's \system\voice\ sub-directory.
In your script the module [snbSampleDetails] is playing numbers: 2919513 (as Digits), and is told to play the sound file forSample.wav just before them.
That forSample.wav sound file should be in the same sound format as the sound files in VoiceGuide's \system\voice\ sub-directory.
Right now forSample.wav is a 22kHz 16bit PCM format. It should be in whatever the system format was selected to at install time. Most likely: 8kHz, 8bit ULaw, but look at format of sound files in \system\voice\ to confirm.
The rest of your sound files used elsewhere in script are 11kHz 8bit, and looks like you have some pre-recorded number sound files in that format already (in x:\sound\common\numbers\ directory) so another (probably preferable) - solution would be to change forSample.wav to be a 11kHz 8bit PCM file and the copy your x:\sound\common\numbers\ sound files into VoiceGuide's \system\voice\ sub-directory. Then all the sound files played back by the Say Numbers module would be in the same 11kHz 8bit PCM format, and probably in the same voice.
Please also see:
http://www.voiceguid...odsaynumber.htm
http://www.voiceguid.../soundfiles.htm
759 081117.651  1528           wav: format=1, channels=1, hz=22050, bytes/sec=44100, bytes/sample=2, bits/sample=16, DataBlockSize=45878  C:\voiceguide\harvest_survey\wav_files\forSample.wav
