Declaring Port Numer Range For Dialout
How to set range of ports to use in dialout? We want to make a markerting dialout action in several available channels.
When limiting dialout to specific ports each of the allowed ports needs to be listed.
eg. to limit outbound dialing to ports 11-20 you will need to list all 10 ports, like this:
11,12,13,14,15,16,17,18,19,20
Where to list outbound dialing ports when portnumber in porttouse table is integer? Shold I change portnumber filed type?
Sounds like you are loading calls yourself directly into the outbound calls database.
To see how the system works please try loading a call using the 'Outbound Call Loader' app and then look at the database tables to see what entries are created.
Basically a new entry needs to be created in the PortToUse table for every port on which the call can be made on.
