Problems With Vbscript Module (Vbscript Accesses A Database)
#1 iTime 22 October 2015 - 08:18 AM
Hi
I have applied the latest patch of VG but could not test the described symptom: when I called in for overall testing, VG failed from the first script.
Could you take a look at the log and let me know what was wrong? The script works fine with the previous version I used.
Thanks.
#2 SupportTeam 22 October 2015 - 08:43 AM
Looks like there is some issue with module [CheckTaskType] - which is a 'Run VBScript' module.
Looks like the VBScript in that module completed without calling Run_ResultReturn etc. and the Fail path was not set, so system hung up the call.
143613.761   9   3   1 state [CheckTaskType] RunScript, wait=1, onhold=
143613.770   9   3   1       rv    replace start (strlen>500)
143613.776   9               rv    dbg   rv_retrieve did not find [UserID] ( 55 73 65 72 49 44)
143613.777   9               rv    dbg   rv_retrieve did not find [AutoNotifyCallID] ( 41 75 74 6f 4e 6f 74 69 66 79 43 61 6c 6c 49 44)
143613.777   9               rv    dbg   rv_retrieve did not find [AutoNotifyMoveNotificationCallID] ( 41 75 74 6f 4e 6f 74 69 66 79 4d 6f 76 65 4e 6f 74 69 66 69 63 61 74 69 6f 6e 43 61 6c 6c 49 44)
143613.777   9               rv    dbg   rv_retrieve did not find [IsHiring] ( 49 73 48 69 72 69 6e 67)
143613.777   9               rv    dbg   rv_retrieve did not find [IsBroadcasting] ( 49 73 42 72 6f 61 64 63 61 73 74 69 6e 67)
143613.778   9   3   1       saving script strIni_moduleRunScript_SaveToFile=True
143613.783   9   3   1       script written to (new file): C:\Program Files (x86)\VoiceGuide\temp\vbs_3_1.vbs
143613.783   9   3   1       runscr waiting. wait=1
143613.785   9   3   1       moh file not specified
143613.785   9   3   1       runscr call ClearScript Execute
143613.785   9   3   1       runscr new VBScriptEngine call
143613.832   9   3   1       runscr .Execute call
143613.848  16         rem   remoting link constructor activated: vgServices_CommandLink
143613.851  16   3   1 rem   RvSet IsMoveAutoNotify, false
143613.852  16   3   1       rv    add   IsMoveAutoNotify|false
143613.854  16   3   1 rem   RvSet TTSSpeed,
143613.854  16   3   1       rv    add   TTSSpeed|
143613.855   9   3   1       engineVbs dispose call
143613.857   9   3   1       runscr .Execute returned. iRunWait=1
143613.857   9   3   1       runscr RunWait_1 script completed
143613.857   9   3   1       runscr sModuleClearScriptProcessWasCalledFrom is current module CheckTaskType, clearing setting
143613.857   9   3   1       runscr RunWait_1 taking fail path as script completed and no next module set
143613.863   9   3   1       HangupCall (RunModule_Script_AfterScriptStarted_1) crn_in=0, L1=Connected, L2=Running_Normal, lPlayId=0, lRecId=0
#3 iTime 22 October 2015 - 08:48 AM
Yes, but why all of sudden?
This module has been running fine for more than 5 years until now with your previous versions.
Did you change functionalities or behaviors of the components?
#4 SupportTeam 22 October 2015 - 09:10 AM
The original trace posted on 13th Oct shows that module running fine (see below).
So there looks to be an issue with the script for some reason.
Currently the script reached this point:
104046.969 20   3   1 rem   RvSet TTSSpeed, 0
But does not reach this point:
104046.990 20   3   1 rem   RvSet_RvList [PlayWelcomeGetEmpNumber]{4001}[GetAppointment]{}[GreetFilePath]{WAV Files\Login_OutdialLoginGreet.wav,WAV Files\Common_CallingFor.wav}[blnIsAppointmentValid]{true}[blnIsMultipleAppointment]{false}[intRetries]{4}[intRetriesTemp]{5}[EmpName]{ SAMUEL SERGEANT}
Can you post the VoiceGuide script itself, or the VBScript from the [CheckTaskType] module ?
From trace supplied on 13th Oct:
104038.772  3   3   1 state [CheckTaskType] type: Script_VBScript, iRunWait=1
104038.780  3   3   1       rv    replace start (strlen>500)
104038.890  3               rv    dbg   rv_retrieve did not find [AutoNotifyMoveNotificationCallID] ( 41 75 74 6f 4e 6f 74 69 66 79 4d 6f 76 65 4e 6f 74 69 66 69 63 61 74 69 6f 6e 43 61 6c 6c 49 44)
104038.890  3               rv    dbg   rv_retrieve did not find [IsBroadcasting] ( 49 73 42 72 6f 61 64 63 61 73 74 69 6e 67)
104038.890  3   3   1       script will be ran from file: C:\Program Files (x86)\VoiceGuide\temp\vbs_3_1.vbs
104038.890  3   3   1       on_hold_file=, iModuleIdx=47
104038.904  3   3   1       delete existing: C:\Program Files (x86)\VoiceGuide\temp\vbs_3_1.vbs
104038.954  3   3   1       current objVbsOrExeProcess (vbsrun) : id=7412, handle=5740, hash=24948291, hasExited=True, startTime=10/9/2015 11:22:53 AM, exitTime=10/9/2015 11:22:55 AM
104038.954  3   3   1       RunVBScriptFile [cscript][C:\Program Files (x86)\VoiceGuide\temp\vbs_3_1.vbs][] timeout=60 (vbsPath=C:\Program Files (x86)\VoiceGuide\temp), start (new Process)
104038.962  3   3   1       objProcess.Start call
104040.510  3   3   1       objProcess.Start returned. handle=5920, id=5536, hash=12601282, starttime=10/12/2015 10:40:39 AM, HasExited=False
104040.584  3   3   1       VBScript started [C:\Program Files (x86)\VoiceGuide\temp\vbs_3_1.vbs], handle=5920, VbsOrExeProcess.WorkingSet=[577536]
104040.592  3   3   1       RunModule_Script_AfterScriptStarted start
104040.592  3   3   1       Run Script waiting. iRunWait=1 (process:5920)
104040.592  3   3   1 t     timer set   1 sec : EV_TIMEOUT_CHECKONSTATE
104040.592  3   3   1       moh file not specified
104046.771 20         rem   vgRemotingCommandLink constructor start, parmameterless
104046.796 20               remoting link constructor activated: vgServices_CommandLink
104046.874 20   3   1 rem   RvSet IsMoveAutoNotify, false
104046.875 20   3   1       rv    add   IsMoveAutoNotify|false
104046.969 20   3   1       rv    add   TTSSpeed|0
104046.990 20   3   1 rem   RvSet_RvList [PlayWelcomeGetEmpNumber]{4001}[GetAppointment]{}[GreetFilePath]{WAV Files\Login_OutdialLoginGreet.wav,WAV Files\Common_CallingFor.wav}[blnIsAppointmentValid]{true}[blnIsMultipleAppointment]{false}[intRetries]{4}[intRetriesTemp]{5}[EmpName]{ SAMUEL SERGEANT}[GreetPasswordPath]{WAV Files\Login_OutdialLoginPassword.wav}
104046.991 20   3   1       rvns  add   PlayWelcomeGetEmpNumber|4001
104046.991 20   3   1       rvns  add   GetAppointment|
104046.991 20   3   1       rvns  add   GreetFilePath|WAV Files\Login_OutdialLoginGreet.wav,WAV Files\Common_CallingFor.wav
104046.991 20   3   1       rvns  add   blnIsAppointmentValid|true
104046.991 20   3   1       rvns  add   blnIsMultipleAppointment|false
104046.991 20   3   1       rvns  add   intRetries|4
104046.991 20   3   1       rvns  add   intRetriesTemp|5
104046.991 20   3   1       rvns  add   EmpName| SAMUEL SERGEANT
104046.991 20   3   1       rvns  add   GreetPasswordPath|WAV Files\Login_OutdialLoginPassword.wav
104046.993 20   3   1 rem   Run_ResultReturn [success] 7
104046.993 20   3   1       q_scr +     cmdRun_ResultReturn 0
104046.993  6   3   1       q_scr run   cmdRun_ResultReturn sCode=[] iActionID=0, crn=0 [0|0|0|0|0][success|||||] 00:00:00 max:1|00:00:00.0980124
104046.993  6   3   1       rv    add   CheckTaskType_ResultReturn|success
104046.993  6   3   1       path {success} found (at offset 3)
104046.993  6   3   1       FindNextVgmTitleInPathList: next module title is=[IsHiringRequested]
104046.993  6   3   1       module's runwait=1, WavPlayWasStarted=0, WavPlayHasNowFinished=0, iRunWait_ExeResult_NextVgm=51
104046.993  6   3   1 t     timer clear (force=False)
104046.993  6   3   1       RunModule start Evaluate, [IsHiringRequested], iModuleIdx=51, previous: vgm=47, vgs=1:1
104046.993  6   3   1 state [IsHiringRequested] Evaluate ["$RV[IsHiring]" = "true"]
#5 iTime 22 October 2015 - 09:24 AM
Please find the attached vgs file.
I also included my VG.ini file just in case it might be erroneous because the file did not have "[ModuleRunScript]" section you mentioned earlier: I added this section to the file by searching other sample file in this forum.
I really hope I do not have to make modifications through the entire scripts of mine after the upgrade.
Thanks in advance.
#6 SupportTeam 22 October 2015 - 09:57 AM
That module is doing some database retrieval, so it may be a good idea to check out if the database connectivity is still working when the that RunVBscript module is ran using the new 'ClearScript' approach.
Some Admin_TraceLogAdd (http://www.voiceguid...tracelogadd.htm) calls throughout the script can help debug that.
most likely the database connectivity is the issue, as in this call:
vg.RvSet RV_LINEID, "TTSSpeed", intTTSSpeed
the intTTSSpeed is not even set (this can be seen in vgEngine trace).
You can set to execute the RunVBscript modules using the old WSH/Wscript approach instead of using the now default ClearScript interpreter by using this VG.INI setting:
[moduleRunScript]
Engine=WScript
(VoiceGuide service restart is required to read in new VG.INI settings)
#7 iTime 22 October 2015 - 10:23 AM
The database connection is fine: VG is sending "SELECT TOP 1..." for checking dial-out table.
And Dial-in activity you read from the log moves from [CheckTaskType] directly to [PlayWelcomeGetEmpNumber] without bothering the SQL server.
If you see from the old log that worked fine, it shows all the comparison modules (IsHiringRequested, IsBroadcastingRequested etc...) will return false and the final destination is [PleayWelcomeGetEmpNumber.], thus no need to connect to the database. Again, please keep in mind that this script has been working fine and I did not change anything: it stopped working with the patch.
Please find the attached log files: I am not sure if this may show some other things, but it is prepared with "Engine=WScript" to retain the old way of scripting.
Thanks.
#8 SupportTeam 22 October 2015 - 11:06 AM
The module [CheckTaskType] now runs fine, we can see in trace that it reaches the Run_ResultReturn call to return 'success' :
170234.522  13   3   1 rem   RvSet IsMoveAutoNotify, false
170234.558  13   3   1       rv    add   IsMoveAutoNotify|false
170234.621  13   3   1 rem   RvSet TTSSpeed, 0
170234.621  13   3   1       rv    add   TTSSpeed|0
170234.623  13   3   1 rem   Run_ResultReturn [success] 7
But something else happened on this call. The call was ended 200ms after being answered, and looks like the hangup arrived from the remote end...
WireShark tracing would be needed here to confirm what SIP messages are exchanged (see www.wireshark.org)
493 170231.480  4720   3 ev    GCEV_ANSWERED crn=8000001 (ktTel_HMP30vista v7.4.5, May 12 2015 12:41:49)
494 170231.480  4720   3       set hli->pCTelProxyhli (in GCEV_ANSWERED). current hli->pCTelProxyhli=05CA4A88, pTelClientEvents=05CA4A88
495 170231.480  4720   3       dx_setevtmsk hmp => -1
496 170231.480  4720   3       dx_clrdigbuf => 0
497 170231.480  4720   3       ResetVoiceBackToItsNetwork dxxxB1C1->iptB1T1
498 170231.480  4720   3       Reset_voice_to_ipt begin. dxxxB1C1:2 to iptB1T1:3 (hli->ct_devinfo_dx.ct_devfamily=0)
499 170231.480  4720           hli->linedev=3 hli->voicedev=2
500 170231.480  4720   3       gc_GetNetCRV not called in non-dialogicSR60 versions
501 170231.480  4720   3 r     Dialogic  GCEV_ANSWERED 2050 (2050 0 0   )
502 170231.481  4720   3       Event_CallState GCEV_ANSWERED iLineCallState=256, hCall=8000001|134217729 m_pktTelProxyClient=00251130
503 170231.481  4720   3 r     CallState GCEV_ANSWERED
504 170231.545  4720   3       ev idx=31 : evttype=2133(2133), crn=0, data=00523748(0ED985C0), len=16(16) q: 0/6
505 170231.545  4720   3 ev    GCEV_LISTEN (2133 0x855) no handler.
506 170231.667  4908           extension saved into zStore_GC_PARM_DATA idx=9
507 170231.670  4720   3       ev idx=32 : evttype=2152(2152), crn=8000001, data=00523778(064E4298), len=8(8) q: 0/6
508 170231.670  4720   3 ev    GCEV_EXTENSION hmp
509 170231.670  4720   3       zStore_GC_PARM_DATA idx=9, set_ID=12303 parm_ID=2 value_size=4
510 170231.670  4720   3       GCEV_EXTENSION IPSET_IPPROTOCOL_STATE
511 170231.688  4908           extension saved into zStore_GC_PARM_DATA idx=11
512 170231.688  4908           extension saved into zStore_GC_PARM_DATA idx=13
513 170231.690  4720   3       ev idx=33 : evttype=2086(2086), crn=8000001, data=005237A8(064E4298), len=8(8) q: 2/6
514 170231.690  4720   3 ev    GCEV_DISCONNECTED crn=8000001
#9 SupportTeam 29 October 2015 - 11:39 AM
Changing the system to run the VBScript modules using the old WSH/Wscript approach fixed the issue of database access problems that were encountered when the new (ClearScript based) approach was used to run the that VBScript.
This different issue of calls being ended soon after they are answered (due to SIP Re-INVITE) is continued in this thread: http://voiceguide.co...showtopic=12141
