Script File With Extensions: *.csv, *.json, *.vgl And Xml
#1 Sebastian 03 December 2015 - 11:56 PM
For what purpose are created files with extensions 'csv', 'json', 'vgl' and 'xml' while saving the VG Script? Are these files in which are stored data declared as "Store result in log file"?
#2 SupportTeam 04 December 2015 - 06:29 AM
These files are script log files. The store information of how a call progressed through that particular script.
please see:
http://www.voiceguid..._scriptlogs.htm
BTW:
They can be turned off by using the VG.INI [Log] Scripts entry
If you make a \log\ subdirectory in the same directory where the script is then these script logs will be saved in the \log\ subdirectory.
