SupportTeam Report post Posted 12/11/2015 03:09 AM The simplest approaches to pass a value from Line A to line B are: 1. VBScript running on line B calls RvGet function with line A's Line Id as first parameter. or: 2. VBScript running on line A sets the RV on line B, using the RvSet function. So the actual test scripts would look something like this: 1. VBScript running on line B calls RvGet function with line A's Line Id as first parameter : set vg = CreateObject("vgServices.CommandLink") sReturnedData = vg.RvGet($RV[AAAA],"RV[client_lineid]") vg.Run_ResultReturn $RV_LINEID, "[lineB_copy]{" & sReturnedData & "}" set vg = Nothing Replace $RV[AAAA] above with $RV that holds the LineId of the line A. And then use a Say Number module to speak out $RV[lineB_copy] as a number. Note that the VBScript module running the above must be set to "Wait until VB Script completes". 2. VBScript running on line A sets the RV on line B, using the RvSet function : This approach would need for you to ensure that line B does not go to the module that uses the RV until after that RV was set from line A. Easiest way is to make the VBScript running on line A to make the script on line B jump to specified module after the RV has been set. So something like this can be used: set vg = CreateObject("vgServices.CommandLink") vg.RvSet($RV[bBBB], "lineB_copy", "$RV[client_lineid]") vg.Script_Goto $RV[bBBB],"my_script.vgs", "mymodule", "" vg.Run_ResultReturn $RV_LINEID, "success" set vg = Nothing or just this : set vg = CreateObject("vgServices.CommandLink") vg.Script_Goto $RV[bBBB], "my_script.vgs", "mymodule", "[lineB_copy]{$RV[client_lineid]}" vg.Run_ResultReturn $RV_LINEID, "success" set vg = Nothing Module mymodule in script my_script.vgs could just be a say Number module that speaks out $RV[lineB_copy] as a number. Share this post Link to post
