Details Of The Connection On Blind Transfer
#1 Sebastian 11 December 2015 - 07:04 PM
How to detect callstatus in blind transfer (busy, connected, unalocated) as $RV? How to get connection timestamp (pick up call by called number) as $RV?
We want to start recording call when callee number pick up the phone in blind transfer. How can we get this functionality?
#2 SupportTeam 11 December 2015 - 07:46 PM
EDIT: the simplest approach is outlined here:
http://voiceguide.co...2194#entry41288
http://voiceguide.co...2194#entry41286
If using ISDN or VoIP lines then the status of the call on any line can be determined using $RV_CALLSTATE
$RV_STATUSDISPLAYED can also be used.
Cause codes of an outgoing call fail are right now not available as an $RV.
Timestamp of when the outgoing call was picked up is right now not available as an $RV.
If you want to start recording when call is answered then an approach you can try looking into is : starting a script on the outgoing leg of the call immediately after the blind transfer is initiated. and in that script wait for events that are fired to script upon outgoing call answer, and start call recording process from that script that is running on the outgoing leg of call.
Please contact sales@voiceguide.com if you have any requests for $RVs to be added to the software.
#3 Maciej 14 December 2015 - 09:29 PM
We tested you suggestions.
$RV_CALLSTATE showing only 'Connected' status even in CDR status was: NOTCONTACTED (not valid subscriber number), DISCONNECTED (subscriber not reachable)
How to reach status like in cdr's
#4 SupportTeam 15 December 2015 - 06:34 AM
The status that is saved in CDR can be accessed using this $RV:
$RV[OutDial_Result]
#5 Sebastian 15 December 2015 - 09:27 PM
We performed tests and unfortunately given variable is empty.
091455.868   7  37  13 state [status_test] Evaluate [$RV[OutDial_Result]]
091455.868   7  37  13       rv    replace start [$RV[OutDial_Result]]
091455.868   7               rv    dbg   rv_retrieve did not find [OutDial_Result] ( 4f 75 74 44 69 61 6c 5f 52 65 73 75 6c 74)
091455.869   7  37  13       rv    replace end   []
091455.869   7  37  13       eval  []
091455.869   7  37  13       objReturn is NULL for input=[], try with Cstr
In CDR we have: DISCONNECTED or NOANSWER.
#6 SupportTeam 15 December 2015 - 11:46 PM
Could you please post the full trace that captures the entire call?
#7 Sebastian 16 December 2015 - 12:07 AM
file in attachment. Calling numer was 222030028 and the called number: 727701727.
#8 SupportTeam 17 December 2015 - 06:31 PM
Looks like you must be referring to this call:
145905.016   7  46  16 state [Dialout_Transfer_Target_blind] Blind Dial and Connect to 9500209727701727
145905.032   7 122  41       ktTel_MakeCall_Enqueue([9500209727701727],CONNECT_IMMEDIATELY, 60,0,46,222333444,<calltype>DialAndConf</calltype><CallerId>222333444</CallerId>)
The $RV[OutDial_Result] must be read from the line on which the outgoing call is made.
Trace shows that script is repeatedly trying to read $RV[OutDial_Result], but it is not reading it from LineId 122.
    Line 245068: 145905.087   7  46  16 state [status_test] Evaluate [$RV[OutDial_Result]]
    Line 246202: 145908.085   7  46  16 state [status_test] Evaluate [$RV[OutDial_Result]]
    Line 247859: 145911.202   7  46  16 state [status_test] Evaluate [$RV[OutDial_Result]]
    Line 249327: 145913.793   7  46  16 state [status_test] Evaluate [$RV[OutDial_Result]]
    Line 250145: 145916.788   7  46  16 state [status_test] Evaluate [$RV[OutDial_Result]]
    Line 251061: 145919.908   7  46  16 state [status_test] Evaluate [$RV[OutDial_Result]]
    Line 253922: 145923.028   7  46  16 state [status_test] Evaluate [$RV[OutDial_Result]]
    Line 254544: 145926.151   7  46  16 state [status_test] Evaluate [$RV[OutDial_Result]]
    Line 256096: 145929.269   7  46  16 state [status_test] Evaluate [$RV[OutDial_Result]]
    Line 257379: 145931.733   7  46  16 state [status_test] Evaluate [$RV[OutDial_Result]]
    Line 258501: 145934.853   7  46  16 state [status_test] Evaluate [$RV[OutDial_Result]]
And you can see how on LineId 122 the $RV[OutDial_Result] value is updated as call progresses:
145905.032   7 122  41       rvns  add   OutDial_Result|NOTCONTACTED
145905.032   7 122  41       ktTel_MakeCall_Enqueue([9500209727701727],CONNECT_IMMEDIATELY, 60,0,46,222333444,<calltype>DialAndConf</calltype><CallerId>222333444</CallerId>) call
145910.782  21 122  41 ev    Dialogic 2081,GCEV_ALERTING, crn=2980111, 2081,0,0,,,
145910.782  21 122  41       rvns  add   OutDial_Result|NOANSWER
145930.586   7 122  41 state [Dialout_Transfer_Target_blind] out_leg 16 <=> 41 9500209727701727 ... connected
145930.586   7 122  41       rvns  add   OutDial_Result|ANSWERED
#9 Sebastian 17 December 2015 - 06:41 PM
Is the value of this variable, we can get only by VB Script? Is there any other way?
#10 SupportTeam 17 December 2015 - 06:53 PM
If you want to get the value of a variable from another line from within a VoiceGuide script then using the "Run VBScript" module is the most straightforward way of doing that.
The VBScript should make a call to the "RvGet" function: http://www.voiceguid...l/com_rvget.htm
and use the LineId of the line from which the RV value is to be retrieved.
#11 Sebastian 17 December 2015 - 07:48 PM
We performed a test according to the given example but the value of the variable is empty.
104120.443  28 107  36 task  runscr Run_VBS vgm=159, file=, engine=[ClearScriptV8]
104120.443  28 107  36       runscr strIni_moduleRunScript_Engine=ClearScriptV8
104120.443  28 107  36 state [get_status] RunScript, wait=1, onhold=
104120.443  28 107  36       rv    replace start
sReturnValue = vg.RvGet($RV[Conf_LineId_2], "$RV[OutDial_Result]")
vg.Run_ResultReturn $RV_LINEID, "Success"
set vg = Nothing
104120.443  28               rv    dbg   rv_retrieve did not find [OutDial_Result] ( 4f 75 74 44 69 61 6c 5f 52 65 73 75 6c 74)
104120.443  28 107  36       rv    replace end   [set vg = CreateObject("vgServices.CommandLink")
sReturnValue = vg.RvGet(149, "")
vg.Run_ResultReturn 107, "Success"
set vg = Nothing]
104120.443  28 107  36       not saving script (strIni_moduleRunScript_SaveToFile is False|0)
104120.443  28 107  36       runscr waiting. wait=1
104120.443  28 107  36       moh file not specified
104120.443  28 107  36       runscr call ClearScript Execute
104120.443  28 107  36       runscr new VBScriptEngine call
104120.444  28 107  36       runscr .Execute call
#12 SupportTeam 17 December 2015 - 07:55 PM
Please change:
to:
sReturnValue = vg.RvGet($RV[Conf_LineId_2], "RV[OutDial_Result]")
ie: remove the "$"
Otherwise, fully formed RVs are replaced before VBScript is executed by the "Run VBScript" module.
Please see the "RvGet" function documentation: http://www.voiceguid...l/com_rvget.htm
#13 SupportTeam 17 December 2015 - 08:19 PM
Also, keep in mind that as you are doing a "Dial and Conference" type transfer here, the original line will be informed of call progress of the call on another line. Call progress events will be sent to the original line.
So to detect if outgoing call has been answered (in situations where a "Dial and Conference" type transfer is done) you can just wait for events that will be sent to line that initiated the transfer.
(instead of repeatedly polling an $RV from the outgoing line)
You can see in vgEngine trace the OTHER_LEG_GCEV_ALERTING and OTHER_LEG_CONNECTED events that are sent to originating line as the outgoing call progresses:
145910.782   7  46  16       se    OTHER_LEG_GCEV_ALERTING 2081  2081|0|0  || LineState=LS_PLAY_PLAYMSGFINISHED
145930.588   7  46  16       se    OTHER_LEG_CONNECTED 0  0|0|0  || LineState=LS_PLAY_PLAYMSGFINISHED
145930.589   7  46  16       se    XFER_ANN_ACCEPTED 0  0|0|0  || LineState=LS_PLAY_PLAYMSGFINISHED
The path to use from the module that is waiting for outgoing call outcome would be:
on {OTHER_LEG_CONNECTED} goto [Handle Connected Call]
#14 SupportTeam 17 December 2015 - 08:54 PM
And as a "Call Transfer" module is being used here then an even simpler approach would be to just have the script wait in the "Dial and Conference" module.
Select "Monitored" transfer instead of "Blind". The script will then wait in the module, and then on call answer a 'Success' path will be taken, and if outgoing call is not answered then a 'Fail' path will be taken.
#15 Maciej 18 December 2015 - 08:45 PM
Sorry, but it don't working.
Can You create and test VBscript working to get data from other channel?
113508.182  29  95  32 task  runscr Run_VBS vgm=161, file=, engine=[ClearScriptV8]
113508.182  29  95  32       runscr strIni_moduleRunScript_Engine=ClearScriptV8
113508.183  29  95  32 state [get_status] RunScript, wait=1, onhold=
113508.183  29  95  32       rv    replace start
set vg = Nothing
113508.183  29  95  32       rv    replace end   [set vg = CreateObject("vgServices.CommandLink")
sReturnValue = vg.RvGet(155, "RV[OutDial_Result]")
vg.Run_ResultReturn 95, "Success"
set vg = Nothing]
113508.183  29  95  32       not saving script (strIni_moduleRunScript_SaveToFile is False|0)
113508.183  29  95  32       runscr waiting. wait=1
113508.183  29  95  32       moh file not specified
113508.183  29  95  32       runscr call ClearScript Execute
113508.183  29  95  32       runscr new VBScriptEngine call
113508.184  29  95  32       runscr .Execute call
113508.188   3         rem   remoting link constructor activated: vgServices_CommandLink
113508.190   3 155  52 rem   RvGet RV[OutDial_Result]
113508.190   3 155  52       rv    replace start [$RV[OutDial_Result]]
113508.190   3 155  52       rv    replace end   [NOANSWER]
113508.193   3  95  32 rem   Run_ResultReturn [Success] 7
113508.193   3  95  32       q_scr +     cmdRun_ResultReturn 0
113508.193   7  95  32       q_scr run   cmdRun_ResultReturn sCode=[] iActionID=0, crn=0 [0|0|0|0|0][Success|||||] 00:00:00 max:7|00:00:00.2530144
113508.193   7  95  32       rv    add   get_status_ResultReturn|Success
113508.193   7  95  32       path {Success} found (at offset 3)
113508.193   7  95  32       FindNextVgmTitleInPathList: next module title is=[status_test_80]
113508.194   7  95  32       module's runwait=1, WavPlayWasStarted=0, WavPlayHasNowFinished=0, iRunWait_ExeResult_NextVgm=160
113508.194  29  95  32       engineVbs dispose call
113508.194  29  95  32       runscr .Execute returned. iRunWait=1
113508.194  29  95  32       runscr RunWait_1 script completed
113508.194  29  95  32       runscr sModuleClearScriptProcessWasCalledFrom is current module get_status, clearing setting
113508.194  29  95  32       runscr RunWait_1 bScriptHasSetNextModule was set. exiting thread.
113508.194   7  95  32 t     timer clear (force=False)
113508.194   7  95  32       RunModule start Evaluate, [status_test_80], iModuleIdx=160, previous: vgm=161, vgs=10:10
113508.194   7  95  32 state [status_test_80] Evaluate [$RV[OutDial_Result]]
113508.194   7  95  32       rv    replace start [$RV[OutDial_Result]]
113508.194   7               rv    dbg   rv_retrieve did not find [OutDial_Result] ( 4f 75 74 44 69 61 6c 5f 52 65 73 75 6c 74)
113508.194   7  95  32       rv    replace end   []
113508.195   7  95  32       eval  []
113508.195   7  95  32       objReturn is NULL for input=[], try with Cstr
113508.196   7  95  32       eval  InvokeMember Eval returned
113508.196   7  95  32       rvns  add   status_test_80_Input|
113508.196   7  95  32       rvns  add   status_test_80|
113508.196   7  95  32       creating new (non-global) rv : call_status_rv
113508.196   7  95  32       rvns  add   call_status_rv|
113508.197   7  95  32       Eval Expr result:[] stored in RV[call_status_rv]
113508.197   7  95  32       matching path not found [], try boolean paths.
#16 SupportTeam 18 December 2015 - 09:06 PM
The VBScript that you are using is not making any use of the sReturnValue variable that should hold the RvGet function response.
suggest that you change
to:
vg.Run_ResultReturn $RV_LINEID, "[TheOtherLinesDialOutcome]{ " & sReturnValue & "}"
and then look at $RV[TheOtherLinesDialOutcome] later in the script.
#17 Maciej 21 December 2015 - 08:55 PM
I reached small success using
vg.Run_ResultReturn $RV_LINEID, "[OutDial_Result__2]{ " & sReturnValue & "}"
'vg.Run_ResultReturn $RV_LINEID, "Success"
set vg = Nothing
but problem is, I detect OutDial_Result after transfer or still monitoring status (loop with OutDial_Result detection) it can be too much for VG because still VG script working.
I made script using loop (RvGet => check OutDial_Result__2 value = > fake play module (silence) => timeout 3 seconds and repeat RvGet) to be sure last dialout status.
Using this loop I reached real dialout status, but VG have to make lot of VBscript threats.
Question is: How to detect last OutDial_Result status in termination script and write this to database? How to make it with lowest resources cost?
I don't know what happen when VG terminating call, how to be sure in termination script using VBScript get data from second line (maybe used by other call).
#18 SupportTeam 21 December 2015 - 09:11 PM
Please see comments here:
and here:
the above outline a better way to react to outgoing leg of the call being connected.
#19 Maciej 21 December 2015 - 10:01 PM
Problem is because we don't see cause's and in case "target not reachable", "wrong number", 'target temporary unavailable or many other statuses
We don't know what exactly happen on other line, so solution is to make blind transfer and allow caller to hear target provider prompts.
In this case we need to store other leg connection status.
Have You idea how to store last other leg call status not using loop (maybe other kind of change status detection)?
needed data is stored in cdr_out file where we have CDR_user data with call_ID.
#20 Maciej 21 December 2015 - 11:49 PM
Generally VG identify only 4 dial out statuses : ANSWERED, NOANSWER, DISCONNECTED, NOTCONTACTED.
I think:
  • ANSWERED mean transfer success with any effect (answering machine, human ...)
  • NOANSWER call without any response from other side, only calling signal, no reaction from other side.
Can You describe causes used in DISCONNECTED, NOTCONTACTED statuses? (to match BUSY, TARGET NOT AVAILABLE, INCORRECT SUBSCRIBER NUMBER ...)
#21 SupportTeam 22 December 2015 - 10:16 AM
The "OTHER_LEG_" events will still arrive on original line that initiated the transfer, even when the blind transfer is used.
The "OTHER_LEG_" events on ISDN system will reflect the ISDN messages received on the outgoing leg. The cause values associated with the "DISCONNECTED" events are not reported. All of the "BUSY, TARGET NOT AVAILABLE, INCORRECT SUBSCRIBER NUMBER" situations result in a DISCONNECTED ISDN event.
The NOTCONTACTED is a CDR Dispostion state for outgoing calls that were sent out but never received any ISDN progress messages in reponse (no 'RINGING/ALERING', no 'DISCONNECTED'. nothing.)
If you are seeing NOTCONTACTED in your outgoing CDR records then this means that your telephony service provided never replied to that outgoing call request.
#22 Maciej 29 December 2015 - 07:15 PM
Can You explain, which "OTHER_LEG_???" data is available?
#23 SupportTeam 29 December 2015 - 08:13 PM
Please see the post made earlier in this thread:
The two OTHER_LEG events that can be listened for are listed there.
