Voiceguide V4.51 Script To Ver 7.51 Script Log Data
#1 Chrisksyeung 02 February 2016 - 04:56 PM
Dear Sir
 Since we upgrade Voiceguide software , The required data log is different
The New Version log below
2016-02-02 11:39:57,7,dxxxB1C4,dxxxB1C4,,,,9,12345,1,LineEvCallState_DISCONNECTED,ThankA,
2016-02-02 12:30:42,7,dxxxB1C4,dxxxB1C4,,,,9,12345,1,Hangup Module,Hang Up,
2016-02-02 12:34:26,3,dxxxB1C2,dxxxB1C2,,,97310762,9,22222,1,Loop Current Off (non-xfer vgm),ThankA,
 Where <Thanks A > is one cell on Script File
Old version log file
2015/12/1 AM 07:06:11,3,,27582766,9,11513,1,2015/12/1 AM 07:06:38
How to let new version log file do not appear RED Colour message
Thankls
#2 SupportTeam 02 February 2016 - 05:25 PM
Are these the .CSV script logs?
The format of these did change in VoiceGuide v7 form previous versions.
If you would like to extract just certain information from the ran script then one option is to crate own log file - concatenating a new line to log file at each call (usually done from the 'after hangup' script)
#3 Chrisksyeung 02 February 2016 - 06:37 PM
Yes
This is a CSV Script logs
I know to know why dispaly different message include Device Name dxxxB1C4 ,
1)  I don't know how to cut the dxxxB1C4 ,
2)  What is after hangup' script
#4 SupportTeam 03 February 2016 - 06:02 AM
The Device name on which call arrived into system is saved in the Script's CSV log file. What is saved in Script's log files is not configurable. The log file reflects what happened during the call.
Please see: http://www.voiceguid...call finish.htm
#5 Chrisksyeung 03 February 2016 - 04:59 PM
I make a staff Attendence CSV File which only wnat to write correct staff ID on CSV File
Can I control the Input data dispaly on CSV File
#6 Chrisksyeung 03 February 2016 - 05:48 PM
Dear Sir
 How to write VB script to get staff ID after staff  press one  to confirm on Vgs Script
#7 SupportTeam 03 February 2016 - 05:56 PM
Probably best to just create own log file.
Please see 'example 2' here: http://www.voiceguid...drunprogram.htm
and the "Save information to a file" example here: http://www.voiceguid...html/modvbs.htm
Have you tried using a "Get Numbers" module (http://www.voiceguid...odgetnumber.htm) to get the 'staff ID' ?
#8 Chrisksyeung 04 February 2016 - 05:52 PM
Dear sir
 I have already use VBcscript  to make a output file , I use $rvstartime to record the staff attendence , How to make this in 12 hour Format
since the output file is 24hr format
#9 Chrisksyeung 04 February 2016 - 06:20 PM
I have already VBscript to output the file
Const ForReading = 1
Const ForWriting = 2
Const ForAppending = 8
set tsFile = fso.OpenTextFile("c:\output.txt", ForAppending, True)
tsFile.WriteLine "$RV_STARTTIME,$RV_CIDNUMBER,$RV[GetID]"
tsFile.Close
set tsFile = Nothing
set fso = Nothing
Hoe to change the Time Format to 12hr Format
#10 SupportTeam 04 February 2016 - 07:17 PM
If you would like 12 hour time then you may need to build your own timestamp string using $RV_HH etc.
see: http://www.voiceguid...ltvariables.htm
But $RV_HH is still 24 hour time so you will need to do some scripting to subtract 12 from it if  $RV_HH value is >12. (and set AM/PM flag at same time)
#11 Chrisksyeung 05 February 2016 - 12:11 PM
Dear Sir
Since I am not progammer , I don't know how to to do some scripting to subtract 12 from it if  $RV_HH value is >12. (and set AM/PM flag at same time)
Can you help me to do script ,since I have already bought  new version of voiceguide
I want show the $RV_starttime in AM/PM format
My scipt below
tsFile.Close
set fso = Nothing
#12 SupportTeam 05 February 2016 - 12:20 PM
If $RV_HH > 12 Then
  ihh = $RV_HH - 12
  tsFile.WriteLine "$RV_DateStamp_Short " & ihh & ":$RV_NN PM,$RV_CIDNUMBER,$RV[GetID]"
Else
  tsFile.WriteLine "$RV_DateStamp_Short $RV_HH:$RV_NN AM,$RV_CIDNUMBER,$RV[GetID]"
End If
tsFile.Close
set fso = Nothing
Edited by SupportTeam, 05 February 2016 - 05:28 PM.
use answer below
#13 SupportTeam 05 February 2016 - 05:28 PM
This is better:
sLog = Date() & " " & Time() & ",$RV_CIDNUMBER,$RV[GetID]"
tsFile.WriteLine sLog
tsFile.Close
set fso = Nothing
#14 Chrisksyeung 12 February 2016 - 06:20 PM
After I use these one ,Const ForReading = 1
tsFile.Close
set fso = Nothing
1)  There are no AM or PM
2) How to change the output file dateformat to ( YYYY/MM/DD, AM , 1:15   )  For : 2016/2/14 PM 1:30 , CallerI ID , ,GETID
#15 SupportTeam 13 February 2016 - 09:19 AM
The Time() function should return the system time in the format specified in Windows' configurations setting.
You can try changing the Windows settings. see: http://windows.micro...y#1TC=windows-7
or you can try using other VBScript time/date formatting functions to get the exact time/date format that you require.
Some more information here:
https://technet.micr...y/ee198902.aspx
http://www.w3schools...f_functions.asp
http://www.w3schools...matdatetime.asp
http://stackoverflow...e-date-time-vbs
#16 Chrisksyeung 16 February 2016 - 12:05 PM
I have already create script which is OK but How to create space replaced the comma by Txt) Tab-separated columns
Below   iscript
set tsFile = fso.OpenTextFile("c:\Program Files\VoiceGuide\Scripts\Meter Reading\IVR2016.txt", ForAppending, True)
If $RV_HH > 12 Then
  ihh = $RV_HH - 12
  tsFile.WriteLine "20$RV_YY/$RV_MM/$RV_DD PM " & ihh & ":$RV_NN:$RV_SS,$RV_CIDNUMBER,$RV[GetID]"
Else
  tsFile.WriteLine "20$RV_YY/$RV_MM/$RV_DD AM $RV_HH:$RV_NN:$RV_SS,$RV_CIDNUMBER,$RV[GetID]"
End If
tsFile.Close
set fso = Nothing
#17 SupportTeam 16 February 2016 - 01:17 PM
Do you just need commas instead of spaces in the saved data? or something else?
Could you please describe n more detail what is required.
#18 Chrisksyeung 16 February 2016 - 01:30 PM
use TAB delimiter-separated values between variable
#19 SupportTeam 16 February 2016 - 01:56 PM
The TAB character in VBScript is represented by this constant:
vbTab
so you can modify the lines like this:
tsFile.WriteLine "20$RV_YY/$RV_MM/$RV_DD" & vbTab & "PM " & vbTab & ihh ":$RV_NN:$RV_SS" & vbTab & "$RV_CIDNUMBER" & vbTab & "$RV[GetID]"
More information here:
https://technet.micr...y/ee198842.aspx
http://powerasp.net/...t-constants.asp
#20 Chrisksyeung 16 February 2016 - 02:22 PM
This wrong result below
2016/02/16 AM 12:18:34” & vbTab & ”” & VbTab & ”12345
#21 SupportTeam 16 February 2016 - 05:25 PM
This looks like the "AM" version, not the "PM" version, recommend checking if you have the quotes in the right places in the "AM" expression.
