Help Altering Lib_num2wav.vbs
I have been having great difficulty in understanding why my alteration of the vbs code in lib_num2wav is not working correctly.
Basically i am trying to get the voice guide say number module to speak additional characters. e.g i want a string of the following format to be spoken #pd+777-4
the original code i am altering is
'name : Digits
'info : Say the digits in the number
'arg1 : Digits to be spoken :
Function Digits(byval arg1)
 'returns a list of comma delimited wav files,
 'with each wav file corresponding to a character
 'in the supplied input string.
 sDigits=Trim(arg1)
 For i=1 To Len(sDigits)
     sDigit = Mid(sDigits, i, 1)
   If sDigit = "-" Then
     sWav = "minus.wav"
   Else
     sWav = sDigit & ".wav"
   end If
   If sOut = "" Then
       sOut = sWav
   else
       sOut = sOut & "," & sWav
   End if
 Next
 Digits = sOut
End Function
now the above code already has a minus character in place. so i have been experimenting with this. I changed the "-" to a "+" and "minus.wav" to "plus.wav". I have recorded the plus.wav sound file and placed it in the correct directory.
But the script does not recognise the + unless i remove:
sDigits=Trim(arg1)
line of code. When i remove this line the + is played a correctly. The consequence of removing this line though is that the say say number module will no longer speak any numbers (only my plus).
How should i code this section so that my characters and digits are spoken? The code i came up with below does not work:
 sDigits=Trim(arg1)
   swav = sdigit & ".wav"
   If sdigit = "-" Then
     swav = "minus.wav"
   end If
   If sdigit = "#" Then
       swav = "hash.wav"
   end If
   If sdigit = "p" Then
       swav = "p.wav"
   End If
   If sdigit = "w" Then
       swav = "w.wav"
   end If
   If sdigit = "+" Then
       swav = "plus.wav"
   end If
   If sOut = "" Then
       sOut = sWav
   else
   End if
 Next
 Digits = sOut
End Function
I am familiar with visual basic but not with vbscript, so maybe i am missing something. Also at present i am altering the code using note pad as i do not know where to find a vbscript utility. (i dont think this should be a problem though)
PLEASE HELP ITS DRIVING ME BONKERS!
Kind regards
Dan
ok i have been experimenting further and i have narrowed down the problem. i have now created a new function in lib_num2wav.vbs called testspeakcode
'name : TestSpeakcode
Function TestSpeakcode(byval arg1)
 FullCode = arg1
 For i=1 To Len(FullCode)
     sDigit = Mid(FullCode, i, 1)
   'swav = sDigit & ".wav"
   If sDigit = "1" Then
      swav = "1.wav"
   End If
   If sDigit = "2" Then
      swav = "2.wav"
   End If
   If sDigit = "3" Then
      swav = "3.wav"
   End If
   If sDigit = "4" Then
      swav = "4.wav"
   End If
   If sDigit = "5" Then
      swav = "5.wav"
   End If
   If sDigit = "6" Then
      swav = "6.wav"
   End If
   If sDigit = "7" Then
      swav = "7.wav"
   End If
   If sDigit = "8" Then
      swav = "8.wav"
   End If
   If sDigit = "9" Then
      swav = "9.wav"
   End If
     swav = "minus.wav"
   End If
   If sDigit = "#" Then
       swav = "hash.wav"
   End If
   If sDigit = "p" Then
       swav = "p.wav"
   End If
   If sDigit = "w" Then
       swav = "w.wav"
   End If
   If sDigit = "+" Then
       swav = "plus.wav"
   End If
   If sOut = "" Then
       sOut = sWav
   Else
   End if
 Next
 TestSpeakcode = sOut
End Function
when i use this function to speak the code the numbers are detected fine but again the characters are just ignored.
I have carefully analysed the trace log and it confirms that the full code is read into voice guide. see log section below:
022640.76  0 rv   add [dct3code1full]{#pw+6171687437+1#}
022640.76  0 rv   add [dct3code2full]{#pw+7735457142+2#}
022640.76  0 TimeoutClear
022640.76  0 [Get ready for codes dct3] Playing
022640.76  0 [Get ready for codes dct3] Playing (C:\Documents and Settings\nabeel\Desktop\sounds for voice\getreadycodesdct3.wav)
022640.81  0 PlaySoundStart ok [C:\Documents and Settings\nabeel\Desktop\sounds for voice\getreadycodesdct3.wav]
022640.81  0 TimeoutClear
022640.81  0 RunModule PLAY end
022640.81  0 wa(17263,18837500)
022658.14  0 Play End line[0] (id=188375)
022658.14  0 ScriptEventCode 8001 iLineState=1100
022658.14  0 LsPlayMsg EV_PLAY_FINISHED
022658.14  0 TimeoutSet 10 EV_TIMEOUT_HANGUP
022658.14  0 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
022658.14  0 ScriptEventCode 9002 iLineState=1101
022658.14  0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
022658.14  0 TimeoutClear
022658.14  0 RVreplace start: [$RV[dct3code1full]]
022658.16  0 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{3/9/2004 2:25:11 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Enter Network1234]{1}[1 Orange]{1}[Enter phone Model]{3310}[Enter phone Model_PathTaken]{matched}[Verify phone model dct3]{1}[Enter imei dct3]{351525002549187}[dct3code1]{6171687437}[dct3code2]{7735457142}[dct3code1full]{#pw+6171687437+1#}[dct3code2full]{#pw+7735457142+2#}
022658.16  0 RVreplace end: [#pw+6171687437+1#]
022658.16  0 [Saycode dct3 code 1] Say numbers: #pw+6171687437+1# as TestSpeakcode
022658.16  0 fn    PlaySoundStartNumbers C:\Documents and Settings\nabeel\Desktop\sounds for voice\hashpwplus.wav, C:\Documents and Settings\nabeel\Desktop\sounds for voice\plus1hash.wav, #pw+6171687437+1#, TestSpeakcode
022658.16  0 sVbsFunctionToUse=TestSpeakcode
022658.20  0 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_0_SayNumber.vbs)
022658.30  0 cl    Play_Start C:\Documents and Settings\nabeel\Desktop\sounds for voice\hashpwplus.wav,6.wav,1.wav,7.wav,1.wav,6.wav,8.wav,7.wav,4.wav,3.wav,7.wav,
.wav,C:\Documents and Settings\nabeel\Desktop\sounds for voice\plus1hash.wav
022658.34  0 PlaySoundStart ok [C:\Documents and Settings\nabeel\Desktop\sounds for voice\hashpwplus.wav,C:\Program Files\VoiceGuide\system\voice\6.wav,C:\Program Files\VoiceGuide\system\voice\1.wav,C:\Program Files\VoiceGuide\system\voice\7.wav,C:\Program Files\VoiceGuide\system\voice\1.wav,C:\Program Files\VoiceGuide\system\voice\6.wav,C:\Program Files\VoiceGuide\system\voice\8.wav,C:\Program Files\VoiceGuide\system\voice\7.wav,C:\Program Files\VoiceGuide\system\voice\4.wav,C:\Program Files\VoiceGuide\system\voice\3.wav,C:\Program Files\VoiceGuide\system\voice\7.wav,C:\Program Files\VoiceGuide\system\voice\1.wav,C:\Documents and Settings\nabeel\Desktop\sounds for voice\plus1hash.wav]
022658.36  0 TimeoutClear
This is very strange, please help!
Dan
Turns out that before passing data to procedures in lib_num2wav.vbs VG 'cleaned' the input to only allow digits 0 to 9 and characters "." and "-".
Attached .exe does not 'clean' the input data.
Please update your v5.2.1 install with this .exe and all should be fine
(you should backup stuff you need from VG's current directory if you are using version prior to v5.2.1 as uninstall will remove entire directory)
[Attached .exe deleted as it contained a bug. new .exe available in subsequent post]
Edited by SupportTeam
Hi, thanks for the suppport, sadly your patched version must have a bug in it as it will not run even a basic script correctly. It either plays no digit/wav files at all or plays the incorrect one. (even using the VG original lib_num2wav.vbs).
I uninstalled VG then installed 5.2.1, I then copied the patch.
befor the patch is applied VG behaves normally after the patch is applied it acts very strange.
I hope you can help.
Dan
OK, we have found the problem. The patched version supplied before did contain a bug - the .exe attached to this post will work.
(previous .exe with bug in it will be removed)
VgMulti_5.2.1009.zip
Hi this version is almost there but it still gives an error when it tries to play characters other than digits. VG does now successfully pass back a string of sound files to be played, but when it attempts to play the first one it gives an error. The sound files are recorded in the correct format and are placed in the correct directory. please see a copy of the trace below:
232924.11  0 rv    add [dct3code1]{6171687437}
232924.13  0 rv    add [dct3code2]{7735457142}
232924.13  0 rv    add [dct3code1full]{#pw+6171687437+1#}
232924.13  0 rv    add [dct3code2full]{#pw+7735457142+2#}
232924.13  0 TimeoutClear
232924.13  0 [Get ready for codes dct3] Playing
232924.13  0 [Get ready for codes dct3] Playing (C:\Documents and Settings\nabeel\Desktop\sounds for voice\getreadycodesdct3.wav)
232924.17  0 PlaySoundStart ok [C:\Documents and Settings\nabeel\Desktop\sounds for voice\getreadycodesdct3.wav]
232924.17  0 TimeoutClear
232924.17  0 RunModule PLAY end
232924.17  0 wa(17263,26773400)
232941.50  0 Play End line[0] (id=267734)
232941.50  0 ScriptEventCode 8001 iLineState=1100
232941.50  0 LsPlayMsg EV_PLAY_FINISHED
232941.50  0 TimeoutSet 10 EV_TIMEOUT_HANGUP
232941.50  0 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
232941.50  0 ScriptEventCode 9002 iLineState=1101
232941.50  0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
232941.50  0 TimeoutClear
232941.50  0 RVreplace start: [$RV[dct3code1full]]
232941.52  0 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{3/11/2004 11:28:11 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Enter Network1234]{1}[1 Orange]{1}[Enter phone Model]{3310}[Enter phone Model_PathTaken]{matched}[Verify phone model dct3]{1}[Enter imei dct3]{351525002549187}[dct3code1]{6171687437}[dct3code2]{7735457142}[dct3code1full]{#pw+6171687437+1#}[dct3code2full]{#pw+7735457142+2#}
232941.52  0 RVreplace end: [#pw+6171687437+1#]
232941.52  0 [Saycode dct3 code 1] Say numbers: #pw+6171687437+1# as Digits
232941.52  0 fn    PlaySoundStartNumbers C:\Documents and Settings\nabeel\Desktop\sounds for voice\hashpwplus.wav, C:\Documents and Settings\nabeel\Desktop\sounds for voice\plus1hash.wav, #pw+6171687437+1#, Digits
232941.52  0 sVbsFunctionToUse=Digits
232941.56  0 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_0_SayNumber.vbs)
232941.61  0 cl    Play_Start C:\Documents and Settings\nabeel\Desktop\sounds for voice\hashpwplus.wav,hash.wav,p.wav,w.wav,plus.wav,6.wav,1.wav,7.wav,1.wav,6.wav,
.wav,7.wav,4.wav,3.wav,7.wav,plus.wav,1.wav,hash.wav,C:\Documents and Settings\nabeel\Desktop\sounds for voice\plus1hash.wav
232941.67  0 PlaySoundStart err=[0 , lPlayId=0x45a32, lOptions=0x0, strOptions=)] [C:\Documents and Settings\nabeel\Desktop\sounds for voice\hashpwplus.wav,C:\Program Files\VoiceGuide\system\voice\hash.wav,C:\Program Files\VoiceGuide\system\voice\p.wav,C:\Program Files\VoiceGuide\system\voice\w.wav,C:\Program Files\VoiceGuide\system\voice\plus.wav,C:\Program Files\VoiceGuide\system\voice\6.wav,C:\Program Files\VoiceGuide\system\voice\1.wav,C:\Program Files\VoiceGuide\system\voice\7.wav,C:\Program Files\VoiceGuide\system\voice\1.wav,C:\Program Files\VoiceGuide\system\voice\6.wav,C:\Program Files\VoiceGuide\system\voice\8.wav,C:\Program Files\VoiceGuide\system\voice\7.wav,C:\Program Files\VoiceGuide\system\voice\4.wav,C:\Program Files\VoiceGuide\system\voice\3.wav,C:\Program Files\VoiceGuide\system\voice\7.wav,C:\Program Files\VoiceGuide\system\voice\plus.wav,C:\Program Files\VoiceGuide\system\voice\1.wav,C:\Program Files\VoiceGuide\system\voice\hash.wav,C:\Documents and Settings\nabeel\Desktop\sounds for voice\plus1hash.wav]
232944.00  0 TimeoutClear
232944.00  0 wa(4425,28523418)
232948.30  0 wa(4425,28523400)
232948.30  0 Play End line[0] (id=285234)
232948.30  0 ScriptEventCode 8001 iLineState=1600
232948.30  0 LsSayNbrPlay EV_PLAY_FINISHED
232948.30  0 TimeoutSet 10 EV_TIMEOUT_HANGUP
232948.30  0 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
232948.30  0 ScriptEventCode 9002 iLineState=1600
232948.31  0 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
232948.31  0 TimeoutClear
I suspect there is still a small bug some where in your code.
Thank you for your continued support!
regards
Dan
Please do:
1. Stop VG
2. Place the appropriate OCX below in your Windows' \System32\ directory.
(if using Dialogic card then use OCX in this post, otherwise use OCX from next post)
3. Start VG again.
If problem persists please also .zip and post both the MMDDvgm.txt and MMDDtw.txt log files
TapiWrap_1.83_for_Dialogic_Analog.zip
