sthibodeau Report post Posted 03/11/2004 03:35 AM When i run my script i am hearing a "Wrong Format" error speech. My script is running nothing but TTS. Any ideas what could be causing this? Scott Share this post Link to post
SupportTeam Report post Posted 03/11/2004 03:55 AM Which version of VG are you using? if not v5.2.1 then please try with v5.2.1 and then post here the Debug Trace Log capturing the problem. (trace should be from v5.2.1) (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
sthibodeau Report post Posted 03/11/2004 04:18 AM Yea i am using 5.2.1003, Here is the log: 201606.47 0 sys cleanup Start 201606.47 0 sys cleanup End 201618.19 6 dial [4,13103086400,403102016,1,2359,MoTuWeThFrSaSu,,1,NONE,C:\Documents and Settings\Owner\Desktop\test.vgs,NONE,none,60,2,120,,none] 201618.19 0 dial callque update id=4 next call time 0403102216 201618.19 0 dial callque DB update returned 201618.19 6 dial found entry: tel[13103086400] ann[NONE] vgs[C:\Documents and Settings\Owner\Desktop\test.vgs] am[NONE] 201618.19 6 Dialing: 13103086400 201618.19 6 MakeCall => 65605 201618.20 6 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE 201618.20 6 TapiCbTrigSet 65605 7002 201618.80 6 tapi Reply (LineEvReply) ok 65605 0 201618.80 6 TapiCbTrigClear 201618.80 6 linedevstate 2048 0 0 201618.80 6 callstate DIALTONE 66476 0 0 201618.81 6 callstate DIALING 66476 0 0 201618.81 6 callstate PROCEEDING 66476 0 0 201618.81 6 callinfo CALLEDID 201618.81 6 callinfo REASON 201618.81 6 Lev_CallerID [0000,] 201618.81 6 callinfo ORIGIN 201634.73 6 callstate CONNECTED 66476,1,0 201634.73 6 WorkingModeTAPI@Connected= 201634.73 6 WorkingModeScript@Connected= 201634.75 6 rv add [OutDial_RetriesLeft]{2} 201634.75 6 rv add [$RV_STARTTIME]{3/10/2004 8:16:34 PM} 201634.75 6 rv add [$RV_DEVICEID]{6} 201634.75 6 rv add [$RV_CIDNAME]{} 201634.75 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 201634.75 6 rv add [$RV_CALLEDNUMBER]{13103086400} 201634.75 0 dial callque delete id=4 201634.77 6 AddRVns [OutDial_Result]{Contacted_Human} 201634.77 6 Live person answered, starting C:\Documents and Settings\Owner\Desktop\test.vgs 201634.77 2 tr NewVgsVgm_Goto C:\Documents and Settings\Owner\Desktop\test.vgs,,,,,0 201634.77 6 rv add [scriptEnd_Time]{3/10/2004 8:16:34 PM} 201634.77 6 rv add [scriptEnd_Goto_Script]{C:\Documents and Settings\Owner\Desktop\test.vgs} 201634.77 6 rv add [scriptEnd_Goto_Module]{} 201634.77 6 rv add [scriptStart_Time]{3/10/2004 8:16:34 PM} 201634.77 0 LoadedVgs_Find C:\Documents and Settings\Owner\Desktop\test.vgs at idx=1 201634.78 6 AddRVns [scriptsPath]{C:\Documents and Settings\Owner\Desktop\} 201634.78 6 cl NewVgsVgm_RunModule module not found: 201634.78 2 tr NewVgsVgm_Goto 1 201634.78 2 tr NewVgsVgm_Goto 2 201634.78 6 TimeoutClear 201634.78 6 [Play 1] Playing 201634.78 6 tts generate start[Hello, my name is Scott please press 1 to be transfered or press 2 to hang up the phone. Thanks you] 201634.80 6 tts generate wait 201634.80 6 RunModule PLAY end 201634.80 2 tr NewVgsVgm_Goto end 201638.11 6 tts generate finish 201638.11 6 [Play 1] Playing (C:\Program Files\VoiceGuide\data\tts6.wav) 201638.11 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady] [C:\Program Files\VoiceGuide\data\tts6.wav] 201638.13 6 TimeoutClear 201638.14 6 tapie PlayEnd old line=6 0 285687 201638.14 6 wa(4433,28568700) 201638.14 6 callinfo MONITORMODES 201642.64 6 Play End line[6] (id=285687) 201642.64 6 ScriptEventCode 8001 iLineState=1100 201642.64 6 LsPlayMsg EV_PLAY_FINISHED 201642.64 6 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG 201648.02 6 Timer fired EV_TIMEOUT_REPLAYMSG 201648.02 6 ScriptEventCode 9005 iLineState=1101 201648.02 6 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 201648.02 6 tts generate reuse 201648.02 6 [Play 1] Playing (C:\Program Files\VoiceGuide\data\tts6.wav) 201648.02 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady] [C:\Program Files\VoiceGuide\data\tts6.wav] 201648.03 6 TimeoutClear 201648.03 6 tapie PlayEnd old line=6 0 295593 201648.03 6 wa(4433,29559300) 201648.03 6 callinfo MONITORMODES 201652.53 6 Play End line[6] (id=295593) 201652.53 6 ScriptEventCode 8001 iLineState=1100 201652.53 6 LsPlayMsg EV_PLAY_FINISHED 201652.53 6 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG 201657.53 0 btn Hangup on line 6 201657.53 6 ScriptEventCode 9001 iLineState=1101 201657.53 6 LsPlayMsgFinished EV_TIMEOUT_HANGUP 201657.53 6 rv add [Hangup Time]{3/10/2004 8:16:57 PM} 201657.53 6 Hanging up call... 201657.53 6 RecSoundStop ok 201657.55 6 PlaySoundStop err=0 201657.55 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 201657.55 6 fnHangupCall end 201657.59 6 linedevstate 2048 0 0 201657.59 6 callstate IDLE 66476 0 0 201657.59 6 WorkingMode@Idle= 201657.59 6 TimeoutClear 201657.59 6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 201657.59 6 tapi Reply (LineEvReply) ok 66459 0 201658.64 6 Timer fired EV_TIMEOUT_TIMETOREINITLINE 201658.64 6 ScriptEventCode 9008 iLineState=900 201658.64 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 201658.64 6 ReinitTelephony due to IDLE 201658.64 6 tapic lineDeallocateCall(MainCall:66476) 0 201658.70 6 lineOpen(6)=> 201658.70 6 Waiting for a call... 201658.70 6 LineHandle=66408 201658.72 6 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 201702.02 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 201702.02 6 ScriptEventCode 9013 iLineState=900 Share this post Link to post
SupportTeam Report post Posted 03/11/2004 04:24 AM Which TTS voice are you using? One of the standard Microsoft voices of have you installed & selected an alternative TTS voice (AT&T etc..) Please .zip and post the file C:\Program Files\VoiceGuide\data\tts6.wav which TTS created and VG is trying to play... Could you also plz post the log file MMDDsw.txt from VG's \log\ subdirectory which captures the TTS file creation (I assume you have logging to file turned on) Share this post Link to post
sthibodeau Report post Posted 03/11/2004 04:46 AM I am using Rhetoricals TTS Server/Engine. I did not have the log checked when running the system earlier, now when i try to recreate the same issue, the system hangs up on me. I have attached a ZIP with the wav file and the logs from that directory, but this oen shows that it hangs up on me. Thanks for you help. 0310vgm.zip Share this post Link to post
SupportTeam Report post Posted 03/11/2004 04:59 AM Please provide traces from a successful call when you can. Meanwhile, can you plz tell us: 1. How was the "Wave Driver not installed error" issue you mentioned in the previous thread resolved? ( http://voiceguide.com/forums/index.php?showtopic=1257 ) 2. Which model/version/release of Rhetorical TTS are you using? Did you purchase it direct from Rhetorical or from a reseller? Can you give us a ballpark price of how much it cost? Share this post Link to post
sthibodeau Report post Posted 03/11/2004 05:12 AM I ended up diabling my game port from my sound card and that seem to resolve the issue. Rhetorical is very expensive and a very large program to run, adds an additional five minutes or so at startup, but its the best sounding system out there hands down. I am using version 4.2 which was purchased directly from them. I have attached there pricing matrix.... Earlier i asked you about LumenVox, is there a VR system out there that can be implemented with VG? Let me know, thanks. Ports_4.2_active.pdf Share this post Link to post
SupportTeam Report post Posted 03/11/2004 05:22 AM At this stage Speech Recognition is not integrated into VG. We will look into what LumenVox offers in the next couple of weeks. Share this post Link to post
sthibodeau Report post Posted 03/11/2004 07:43 PM Ok i was able to recreate the errror again, i have attached the log files. Prior to getting the system to say the error message, the system thought i was an answering machine everytime it called my cellphone. Please look at the log files and let me know why i am getting the error message with the TTS - Thanks. 0311sw.zip Share this post Link to post
SupportTeam Report post Posted 03/11/2004 10:21 PM the system thought i was an answering machine everytime it called my cellphone. This sometimes happens if the phone connection is poor quality (or has been heavily compressed during transmit by telephone company). We had a few people report this on CDMA type mobile phones... Regarding the TTS error we can now see what is happening. The TTS engine is not actually completing the writing of the TTS file, although it claims that it has. Looks like sections of the WAV header are not written in, which then stops VG from correctly playing the file. The attached .exe will give the TTS a bit more time to do it's job and will check the file itself for when it is ready to be played. Please update your v5.2.1 install with this .exe, run a few calls and post the trace files so that we may confirm that all is working on your system as intended. VgMulti_5.2.1010.zip Share this post Link to post
