Different Dialogic Cards
#1 jiaseby 08 December 2017 - 03:17 AM
Can I use 2 different Dialogic 4 port cards on one machine to have 8 lines?  Or do they have to be the exact same model?
#2 SupportTeam 08 December 2017 - 06:39 AM
You cannot mix 'JCT' series cards and D/4PCI series cards.
Either both cards have to be D/4PCI family cards or both have to be 'JCT'
D/41JCT is the only 4 line analog card in JCT family. There are many types of D/4PCI cards, all can work in same system together.
If you have two or more JCT cards in the computer then you have to link all the cards together with a "CT Bus cable". (see the installation instructions that come with JCT cards)
D/4PCI cards do not have to be linked together with CT Bus cable. (D/4PCI do not have a CT Bus connector)
If you need 8 lines then recommend looking at using a D/120JCT card. It is a 12 line card.
#3 researcher 08 December 2017 - 10:10 PM
This is a good offer for 12 lines
https://www.ebay.com...ZgAAOSwbopZUQMP
#4 SupportTeam 08 December 2017 - 10:14 PM
Yes. And this card is a PCIe card.
