VoiceGuide: Emailing From Data Used In Voiceguide.commandlink - VoiceGuide
Page 1 of 1
  • Login to start a new topic
  • You cannot reply to this topic
#1 User is offline   Brandon Icon
  • Group: Members
Posted 21 March 2004 - 08:20 PM
I want to email several different types of forms to multiple people. I have all of the email addresses entered into the voicemail section. These email address show up between the <EmailForward> and </EmailForward> tags in the VmBoxList.xml file.
Do you have a VB script that will grab this information from VoiceGuide.CommandLink and assign it a $RV variable to I can use this variable on the To: line of the send email module?
Thnaks,
-Brandon
Attached File(s)
#2 User is offline   SupportTeam Icon
  • Group: Admin
Posted 21 March 2004 - 10:56 PM
I think what you are asking is how to find out what the "EmailForward" setting is for a particular voicemail box, correct?
Please see the VoiceGuide help file's section on COM command Vm_VmbConfig_Get
eg: to find out the forwarding email address for voicemail box 0001 you would use:
sEmailAddr = vg.Vm_VmbConfig_Get("0001", "EmailForward")
#3 User is offline   Brandon Icon
  • Group: Members
Posted 22 March 2004 - 10:47 AM
Now that sEmailAddr has been identified. Example sEmailAddr = Brandon@aol.com How do I send a new email to this email address?
I want to run the email module and put the Brandon@aol.com on the To: line?
Do I need to convert sEmailAddr to a $RV value?
Thanks,
-Brandon
#4 User is offline   Brandon Icon
  • Group: Members
Posted 22 March 2004 - 10:52 AM
$RV[Get Email Address] = sEmailAddr
Can I now go to my email module and put in $RV[Get Email Address] on the To: Line?
Is the blue line above correct?
Thanks for all the help!
-Brandon
#5 User is offline   SupportTeam Icon
  • Group: Admin
Posted 22 March 2004 - 11:49 AM
The approach would be to use something like this in the "Run VB Script" module:
vg.Run_ResultReturn iLineId, "[RetrievedEmailAddress]{" & sEmailAddr & "}"
set vg = Nothing
and then use
$RV[RetrievedEmailAddress]
in the "Send Email" module.
This post has been edited by SupportTeam: 26 March 2004 - 10:52 AM
#6 User is offline   Brandon Icon
  • Group: Members
Posted 22 March 2004 - 11:56 AM
You all are to Cool!
The support on this site is top notch!
This is the reason that you are highly talked about in a positive manor.
Thanks again,
-Brandon
#7 User is offline   SupportTeam Icon
  • Group: Admin
Posted 26 March 2004 - 10:54 AM
QUOTE
BTW. The sample script supplied before was using the incorrect COM command to return information to VoiceGuide - it has now been corrected to use the "Run_ResultReturn"
Page 1 of 1
