Please look in VoiceGuide's log subdirectory - there should be a log file there named MMDDes.txt (MMDD is current month and day).
If you do not see this file then edit VG.INI to have the logging settings set to "10" :
QUOTE
[Log]
;Automated "log-to-file" logging.
;To turn OFF logging for a particular application set it's entry to 0
;To turn ON all logging for a particular application set it's entry to 10
;all log files are saved in VoiceGuide's \log\ subdirectory
;log files are names as following:
;VoiceGuide: MMDDvgm.txt
;NumberLoader: MMDDtnl.txt
;EmailSender: MMSSes.txt
;TapiWrapOcx: MMDDtw.txt
;SapiWrapOcx: MMDDsw.txt
VoiceGuide=10
NumberLoader=10
VoicemailManager=10
EmailSender=10
TapiWrapOcx=10
SapiWrapOcx=10
and then attempt to send an email again.
The MMDDes.txt will usually say in plain english why the email was not sent.
If you still have problems after looking at this log file then please post the file here and we can take a look at it.
Just for reference, here is what a trace of a successful send looks like (for demonstration first SMTP server name is faulty and VG then uses the backup SMTP server to send out the email):
QUOTE
144327.78 0 eng prog start 14:43:27 02 Jul
144327.89 0 que found 1/1
144327.89 0 que current: ID=2
144327.89 0 que update ID=2to SendTime=0407021444 SendRetriesLeft=2
144327.91 0 smtp Status Connecting to SMTP Server (mail5.bigpond.com)...
144327.98 0 smtp SendFailed Authoritative answer: Host not found
144327.98 0 smtp Status Closing Connection...
144328.00 0 eng send attempt 1 result = [fail]
144328.00 0 smtp Status Connecting to SMTP Server (mail.bigpond.com)...
144328.06 0 smtp Status Initializing Communications...
144328.11 0 eng smtp send start To:destsend@katalina.com.au, Cc:cc@katalina.com.au, Bcc:
144328.11 0 smtp Status Sending Sender Information...
144328.11 0 smtp Progress 11%
144328.59 0 smtp Status Sending Recipient Information...
144328.59 0 smtp Progress 21%
144328.63 0 smtp Progress 29%
144328.66 0 smtp Status Sending Message...
144328.66 0 smtp Progress 30%
144328.70 0 smtp Progress 100%
144328.84 0 smtp Progress 100%
144328.84 0 smtp Status Transmission Complete...
144328.84 0 smtp SendSuccesful
144328.84 0 que delete ID=2
144328.84 0 eng smtp send end
144328.84 0 smtp Status Closing Connection...
144328.88 0 eng send attempt 2 result = success
144328.98 0 eng prog end 14:43:28 02 Jul
