ktruk Report post Posted 01/28/2005 03:44 PM Is there a way to incorporate a "star" button as data input? I have a need for users to able to put in a "*" instead of this terminating input. I have three possible uses: 1. to be used as decimal point. 2. to be used to denote an extention number. 3. to be used to punctuate a number Even if current release does not do this how feasible would it be to do this in a lter release? and if so, how long would it take? This does not user-interface support, a simple VG.INI setting would suffice. I realize that there would be consequences, such as me producing custom 'number-speaking' scripts, but that doesn't look too bad! Thanks - Tim. PS: Your 10 minute 'flood control' on postings is a real pain! Share this post Link to post
SupportTeam Report post Posted 01/28/2005 09:55 PM The VoiceGuide GetNumbers module can react to the * character. from VG help file: ‘*’ Paths If an "on {*} " path is defined then pressing the * key results in VoiceGuide assigning a "*" to the Result Variable for the module and going down the "on {*} " path. This feature can be used to easily implement a "press * to correct" option - just point the "On {*} " path back to the same module and then when caller presses the * key they will be able to just start entering the number again from start. If a "on {*} " path is not specified then the * key has a similar function to the # key - when pressed it will be interpreted to signal end of data input. If you want to use the * as a decimal point you can just use the * path to jump to another Get Number module which will listen for the digits which are after the decimal point. Share this post Link to post
ktruk Report post Posted 02/03/2005 03:51 PM Okay - thanks, I will try the on {*} to link to a "get extention" input-number module, but I would still like the option of embedding a * in a string of input digits and returned as an arbirary string of digits with stars anywhere in the string. Something for the future perhaps? Thanks - Tim. Share this post Link to post
SupportTeam Report post Posted 02/03/2005 11:58 PM Update your v5.2.3 install with this .exe. You will now be able to enter * keys in a Get Numbers module (as long as the "On {*} goto ..." path is not explicitly defined) VgMulti_5.2.3066.zip Share this post Link to post
